10
[ROM] Official Cm13 nighties are out !
  1. baddison1
    Gingerbread Jul 25, 2016
  2. Flamehell
    Flamehell , Jul 25, 2016 :
    Last nightly?And do you know if cyandelta is working?Tnx :)
  3. MNavy_
    KitKat Jul 25, 2016
  4. obiwan+
    Honeycomb Jul 25, 2016
    obiwan+ , Jul 25, 2016 :
    I will try it, but I'm still a noob. If it bricks my device, it's covered by the warranty, right?
  5. stephenboyo
    KitKat Jul 25, 2016
  6. jerrymilton
    Jelly Bean Jul 26, 2016
  7. obiwan+
    Honeycomb Jul 26, 2016
    obiwan+ , Jul 26, 2016 :
    I think Cyanogenmod makes the display better. With default settings, I can now see up to block 3 in this grey scale test: http://www.lagom.nl/lcd-test/black.php
    Before I believe it was much worse. I should have taken a photo before changing the OS.
    Edit: Nope, no difference to current stock ROM. Must have mistaken this for another device.
  8. G_Lukas_Herman_UjbV
    Cupcake Jul 26, 2016
    G_Lukas_Herman_UjbV , Jul 26, 2016 :
    I've been using official cm 13 for 1 day now. Everything is working fine. The only problem is only when I want to restore my apps from the previous rom, I always get stuck on installing any apps.
  9. michdeskunk
    Gingerbread Jul 26, 2016
  10. bakerbarber
    Jelly Bean Jul 27, 2016
    bakerbarber , Jul 27, 2016 :
    The LTE signal is terrible. What is the problem?
    How could it be so much better with Oxygen?
    I had to restore from backup. I don't like Oxygen but what can I do?
    Thanks so much for the CyanogenMod, but I don't think I can use it until it gets a little better.
  11. jak
    Ice Cream Sandwich Jul 27, 2016
    jak , Jul 27, 2016 :
    Was it really better, or did it just look better? Oxygen shows you full signal at awful signal levels... (like: No data gets through, RSRQ of -15, and once you want to use it, it drops to HSPA, and then to EDGE).
    IIRC, there's some region setting somewhere or something, though.
  12. michdeskunk
    Gingerbread Jul 27, 2016
    michdeskunk , Jul 27, 2016 :
    I have problem with gallery crash.. the images previews aren't always visible and sometime when I open or play a video gallery crash...
    Video recording don't store video in gallery
  13. Wendal
    Cupcake Jul 27, 2016
    Wendal , Jul 27, 2016 :
    anyone able to encrypt their phone? I installed the 0723 Nightly, and cannot encrypt my phone. Sync my corp email demands it, this is a showstopper. It was fine on Garak's 7/3 build.
  14. michdeskunk
  15. jak
    That's weird. It should be broken in the 26 nightly, but not in the 23,24,25,27 ones.
  16. Wahoux
    Lollipop Jul 28, 2016
    Wahoux , Jul 28, 2016 :
    noob question, I must use the CM custom recovery with the nightly or I can use TWRP?
  17. tobias14
    Ice Cream Sandwich Jul 28, 2016
    tobias14 , Jul 28, 2016 :
    Twrp will do just fine
    Wahoux likes this.
  18. Wahoux
    #38
    tobias14 likes this.
  19. rclotz
    Honeycomb Jul 29, 2016
    #39
    Mydealz likes this.
  20. Deactivated User
    Jul 29, 2016
    #40
