10
[ROM] Official Cm13 nighties are out !
  1. countthesaints
    Froyo Jul 31, 2016
    #61
  2. masaga91
    Gingerbread Jul 31, 2016
    #62
  3. NaterTots
    Jelly Bean Jul 31, 2016
    NaterTots , Jul 31, 2016 :
    Going by posts, just like it worked on Oxygen OS. ;)
    #63
  4. jak
    Ice Cream Sandwich Jul 31, 2016
    jak , Jul 31, 2016 :
    People on XDA do complain about gallery crashes and mtp issues with sdcardfs (some using f2fs, not sure which):
    http://forum.xda-developers.com/showpost.php?p=67978274&postcount=656
    http://forum.xda-developers.com/oneplus-3/development/rom-unofficial-cyanogenmod-13-t3399089/page65
    dianlujitao seems to be checking some things.
    #64
  5. bhanuteja200bc
    Honeycomb Jul 31, 2016
    #65
  6. Sighn
    Gingerbread Aug 1, 2016
    Sighn , Aug 1, 2016 :
    Anyone get mysterious restarts? I started getting them on OxygenOS 3.2.2. Now I've had the same kind of sudden restart on this ROM (29/July nightly). I take the phone out of my pocket only to be greeted with a pin-request to login. I already had sdcardfs entry already set to false.
    #66
  7. tonyHTX
    Froyo Aug 2, 2016
    tonyHTX , Aug 2, 2016 :
    I followed these instructions and my phone no longer restarts from using the gallery.
    Edit: This information as been deemed invalid!
    #67
  8. Magnetic Nerd
    Jelly Bean Aug 2, 2016
    Magnetic Nerd , Aug 2, 2016 :
    Tried a few nightlies but think I'm gonna wait it out until this camera issue is sorted out
    #68
  9. RoggaRolla
    Honeycomb Aug 3, 2016
    #69
  10. tonyHTX
    Froyo Aug 3, 2016
    #70
  11. AcmE85
    Ice Cream Sandwich Aug 4, 2016
    AcmE85 , Aug 4, 2016 :
    THIS IS WRONG, the rest is correct though.
    CM13 did not switch to F2FS and still uses EXT4 by default. This has nothing to do with this issue, although you are right that it does not occur with F2FS.
    https://review.cyanogenmod.org/#/c/155164/
    The next nightly will revert the commit which causes this issue and fix this for EXT4.
    sdcardfs has nothing to do with the used filesystem.
    edit: another dev confirmed this on XDA
    http://forum.xda-developers.com/oneplus-3/development/rom-unofficial-cyanogenmod-13-t3399089/page116
    Please don't spread false information here.
    #71
    tonyHTX, obiwan+ and RoggaRolla like this.
  12. Racpu_
    Froyo Aug 4, 2016
    Racpu_ , Aug 4, 2016 :
    https://download.cyanogenmod.org/get/jenkins/172784/cm-13.0.1-20160804-NIGHTLY-oneplus3.zip
    • op3: Support for OP3 camera modes (android_device_oneplus_oneplus3)
    • op3: Update FOSS config (android_device_oneplus_oneplus3)
    • SnapdragonCamera: Disable CDS and TNR if SeeMore is enabled (android_packages_apps_Snap)
    • SnapdragonCamera: Fix the issue that IS is not disabled (android_packages_apps_Snap)
    • SnapDragan: Changes to enable UI option for ASD mode. (android_packages_apps_Snap)
    • SnapdragonCamera: Disable continuous shot when HDR is enabled (android_packages_apps_Snap)
    • SnapdragonCamera: Fix AEC lock issue after non-zsl snapshot. (android_packages_apps_Snap)
    • SnapdragonCamera: Fix face detection UI offset (android_packages_apps_Snap)
    • SnapdragonCamera: fix a panorama memory leak (android_packages_apps_Snap)
    • SnapdragonCamera: fix crash with persist.panel.orientation (android_packages_apps_Snap)
    • SnapdragonCamera: fix camera FC when internal storage isn't enough (android_packages_apps_Snap)
    • SnapDragon: Changes to fix popup menu issue in camcorder (android_packages_apps_Snap)
    • SnapdragonCamera: Fix app auto close when repeat plug in/out USB cable (android_packages_apps_Snap)
    • SnapdragonCamera: Fix app crash when taking longshot during countdown (android_packages_apps_Snap)
    • SnapdragonCamera: fix crash after photo deletion (android_packages_apps_Snap)
    • SnapdragonCamera: limit AF animation FPS (android_packages_apps_Snap)
    • SnapdragonCamera: Reduce number of countdown timer option (android_packages_apps_Snap)
    • SnapdragonCamera: Fix FD roll_dir issue (android_packages_apps_Snap)
    • SnapdragonCamera: Fix display smaller thumbnail on panorama preview (android_packages_apps_Snap)
    • SnapdragonCamera: Use StorageManager for SDCard (android_packages_apps_Snap)
    • SnapdragonCamera: Fix app freeze when connect to camera failed (android_packages_apps_Snap)
    • SnapdragonCamera: add button border (android_packages_apps_Snap)
    • SnapdragonCamera: Limit preview size by capping display dimensions. (android_packages_apps_Snap)
    • SnapdragonCamera: Reduce the latency for panorama preview starting (android_packages_apps_Snap)
    • SnapdragonCamera: Fix not able to view other pictures when macro mode (android_packages_apps_Snap)
    • SnapdragonCamera: Fix the preview thumbnail issue (android_packages_apps_Snap)
    • SnapdragonCamera: Fix progress indicator overlapped by thumbnail icon (android_packages_apps_Snap)
    • SnapdragonCamera: Always enable FD with TruePortrait on (android_packages_apps_Snap)
    • SnapdragonCamera: Reset navigation bar state whenever screen turns on (android_packages_apps_Snap)
    • SnapdragonCamera: Fix to make back key event work normally (android_packages_apps_Snap)
    • SnapdragonCamera: Handle startPreview exception in camera. (android_packages_apps_Snap)
    • VideoModule: Removing tmpPath and use path (android_packages_apps_Snap)
    • SnapdragonCamera: Fix crash issue with enable FD with TruePortrait (android_packages_apps_Snap)
    • SnapdragonCamera: Do not update panorama thumbnail when cancelled (android_packages_apps_Snap)
    • SnapdragonCamera: Improving Burstmode performance (android_packages_apps_Snap)
    • SnapdragonCamera: Adding toast for media recording failure. (android_packages_apps_Snap)
    • SnapdragonCamera: Adding current camera null check (android_packages_apps_Snap)
    • SnapdragonCamera: Removing filmstrip view touch handler (android_packages_apps_Snap)
    • SnapdragonCamera: Register media status listener (android_packages_apps_Snap)
    • SnapdragonCamera: Adding null exception handler. (android_packages_apps_Snap)
    • SnapdragonCamera: Fix menu highlight issue when rotating device (android_packages_apps_Snap)
    • SnapdragonCamera: fix null pointer exception (android_packages_apps_Snap)
    • SnapdragonCamera: Reset menu when device is rotated (android_packages_apps_Snap)
    • SnapdragonCamera: Fix missing icon issue in error condition (android_packages_apps_Snap)
    • Fix android.process.media got killed when capture (android_packages_apps_Snap)
    • SnapdragonCamera: Resolve camera control overlapping issue (android_packages_apps_Snap)
    • SnapdragonCamera: hide the preview surface during suspend (android_packages_apps_Snap)
    • SnapdragonCamera: Fix viewfinder flashing issue in camcorder mode (android_packages_apps_Snap)
    • SnapdragonCamera: Removing unnecessary orientation check (android_packages_apps_Snap)
    • SnapdragonCamera: Add support for outputting MPO format files (android_packages_apps_Snap)
    • SnapdragonCamera: resolve touch af issue during countdown (android_packages_apps_Snap)
    • SnapdragonCamera: Fix incorrect focus mode (android_packages_apps_Snap)
    • SnapdragonCamera: adjust video recording duration margins (android_packages_apps_Snap)
    • SnapdragonCamera: Add manufacture and model info (android_packages_apps_Snap)
    • SnapdragonCamera: Fix the issue that camera control is removed (android_packages_apps_Snap)
    • SnapdragonCamera: Fix panorama cancel button location (android_packages_apps_Snap)
    • SnapdragonCamera: implement optizoom and chromaflash UI (android_packages_apps_Snap)
    • SnapdragonCamera: Fix the advanced features relative toast issue (android_packages_apps_Snap)
    • snap: Add missing resource (android_packages_apps_Snap)
    • snap: Always turn touch-af-aec on (android_packages_apps_Snap)
    • snap: Fixes for advanced features and scene modes (android_packages_apps_Snap)
    • snap: Additional fixes for auto-HDR mode (android_packages_apps_Snap)
    • snap: Add constrained longshot mode (android_packages_apps_Snap)
    • Revert "Revert "Revert "Revert "Revert "op3: Enable sdcardfs""""" (android_device_oneplus_oneplus3)
    • surfaceflinger: Fix uninitialized variable (android_frameworks_native)
    • framework: don't allow assist activities while not provisioned (android_frameworks_base)
    • version: Set version string to 13.0.1 to reflect security update (android_vendor_cm)
    • surfaceflinger: Add check for number of queued buffers (android_frameworks_native)
    • surfaceflinger: Unbreak casting and other use cases (android_frameworks_native)
    • Tele2 (LT) APN updates (android_vendor_cm)
    #72
    runboy93, Mydealz and obiwan+ like this.
  13. stephenboyo
    KitKat Aug 4, 2016
    stephenboyo , Aug 4, 2016 :
    Not that great! Try Resurrection Remix. Much better with even faster dash charging and 150K on antu tu and its based on CM13 with lots more customisation options.
    #73
  14. runboy93
    Jelly Bean Aug 4, 2016
  15. Savo83
    Honeycomb Aug 5, 2016
    Savo83 , Aug 5, 2016 :
    Dash charging is identical to oxygen with cyanogenmod.
    I have no idea what you're smoking.
    #75
    rclotz and Mydealz like this.
  16. Savo83
    #76
    obiwan+ likes this.
  17. stephenboyo
    KitKat Aug 5, 2016
    stephenboyo , Aug 5, 2016 :
    If you're talking about Resurrection Remix yes. Not CM13. CM13 at the time I tried it last week was heavy and much slower than stock Oxygen, so I know what I'm smoking:p
    #77
  18. tobias14
    Ice Cream Sandwich Aug 5, 2016
    #78
  19. tonyHTX
    Froyo Aug 5, 2016
    tonyHTX , Aug 5, 2016 :
    Hey thanks for the corrections! I was just taking what was said in the post as true. My mistake and please disregard!
    #79
    AcmE85 likes this.
  20. AcmE85
    Ice Cream Sandwich Aug 6, 2016
    AcmE85 , Aug 6, 2016 :
    No worries, maybe my response was a bit harsh. Sorry if I offended you.
    #80
