25
[ROM] [OnePlus3] [7.1.1] [Unofficial] Resurrection Remix [Substratum] [DayDream]
  1. giveme13s
    Gingerbread Jan 4, 2017
    giveme13s , Jan 4, 2017 :
    Split screen working fine for me...
  2. whodatboi
    KitKat Jan 5, 2017
  3. G_Johanes_Pao_nFAS
    Cupcake Jan 5, 2017
    G_Johanes_Pao_nFAS , Jan 5, 2017 :
    I'm new to nougat and rarely use the split screen in the past, so I don't really know how does the "original" split screen works. So, I went ahead and search in google, from what I can see, there's no difference between the original split screen and the one we're having in this ROM. Did I miss your point?
  4. vivekdn2504
    Donut Jan 5, 2017
  5. giveme13s
    Gingerbread Jan 5, 2017
    giveme13s , Jan 5, 2017 :
    Perhaps @G_Rishi_Findley_xOCV meant "floating window" where we can resize and move a floating window of an app anywhere on screen
    whodatboi likes this.
  6. whodatboi
    KitKat Jan 5, 2017
    whodatboi , Jan 5, 2017 :
    it may have been called floating window idk.
    but it was very basic. click the button that had 2 rectangular boxes on it when in the recents launcher and selected top or bottom dependent on which app you wanted to split with, the one above it in the recents or below it.
    Anyway just wanted to report my surprisingly amazing battery life with this ROM. never had better battery my whole ROM life!
    the blank spot is just me flashing some files via twrp. tried out arise and didn't like it. I also thot I was running MM and trued flashing xposed lol
  7. whodatboi
    KitKat Jan 5, 2017
    wish I could tell you. I'm on T-Mobile but I can't get google dialer to work since the latest update. which is weird AF so I'm using dialer +.
    I swear to god this ROM hates me or some shit I have had more issues with it than a 50yr old Oldsmobile. but other than unstable camera (using camera FV-5 as replacement) and no google dialer the ROM is super stable.
    I do however have a request for @giveme13s in the next update you should enable google assistant functionality by default. I enabled it on mine and I'm loving it so far
  8. giveme13s
    Gingerbread Jan 6, 2017
    SpaZioMilano, whodatboi and dslsd like this.
  9. giveme13s
    giveme13s , Jan 6, 2017 :
    Will try incorporating google assistant on next build ... :fingers-crossed:
  10. whodatboi
    KitKat Jan 6, 2017
    whodatboi , Jan 6, 2017 :
    thanks
  11. whodatboi
    KitKat Jan 6, 2017
    I'll try a dirty flash and see what's up
  12. lartsch
    Eclair Jan 6, 2017
    lartsch , Jan 6, 2017 :
    But please, not using the ChopAssistant workaround for the broken "Ok google" enrollment :D
    giveme13s and whodatboi like this.
  13. robbiegast
    Honeycomb Jan 6, 2017
  14. whodatboi
    KitKat Jan 6, 2017
    where are you hearing the echo?
    I'm not hearing it on my end
  15. whodatboi
    KitKat Jan 6, 2017
    I'm using that workaround right now. doesn't bother me too much.
  16. nikhilsnigam
    Froyo Jan 6, 2017
    nikhilsnigam , Jan 6, 2017 :
    Can you check if inbuilt snap cam's touch to focus is working?
    For me it isn't. Todays build clean flash.
    giveme13s likes this.
  17. G_Kanokanor_Seme_(Kano)_
    Cupcake Jan 6, 2017
    SpaZioMilano likes this.
  18. SpaZioMilano
    SpaZioMilano , Jan 6, 2017 :
    hi! is it stable, the battery is it good? Bluetooth,GPS,data, wifi etc work good?
    let me know? I search the Rom for me :)
  19. nicesoni_ash
    Eclair Jan 6, 2017
    nicesoni_ash , Jan 6, 2017 :
    Would you mind giving the proper git links. I understand you build based on these sources but you must be uploading your own version somewhere? That git link.
  20. giveme13s
    Yup. confirmed. Touch to focus is not working
