ROM with best battery life?
  1. eobrien84
    Froyo Jul 14, 2016
    eobrien84 , Jul 14, 2016 :
    For the people that have tried multiple ROMs, which have you found to have the best battery life? I'm on CM13 snapshot and lately the battery has gotten a little inconsistent. Which ROM should I try for the best battery? I don't need a ton of themes/customization options.
  2. Slatter191
    Lollipop Jul 14, 2016
    Slatter191 , Jul 14, 2016 :
    COS 13.1 1K......depending on usage, varies on my OPOs, 4.5-6.5 hrs. (Stock non rooted.)
    Gonzo01 likes this.
  3. itsinder
    Froyo Jul 14, 2016
  4. bright_wal
    Honeycomb Jul 14, 2016
    bright_wal , Jul 14, 2016 :
    1. DarkobasRom by markoman,build 06/02 6-7hrs sot avg user. Stock kernel and lightning kernel v41c
    2. Int3ns3-Darkobas by int3ns3,build 07/09 5.5-6 hrs sot avg user. With lightning kernel v41
    2. Sultanxda cm13,build 06/24 5.5-6hrs sot with stock kernel
    All three ROMs best ROMs for camera, battery and performance.
    This is the truth.
    Deactivated User likes this.
  5. Deactivated User
    Jul 14, 2016
