Tarfex
Ice Cream Sandwich
Apr 11, 2016
I have tried many different Android M roms; sultan, darabos, Dirty unicorn, nuclear Android project, tuga power, stock COS 13, AOSP Paradox, slim saber 6.0.1
but for some reason. All of them lag except for TugaPower. For example: Google play music takes forever to load and then it crashes, but it won't do that on tuga power. Or I lock the screen and when I press the power button once or double tap to wake. The screen stays black and the buttons light up and it takes forever to turn on. Or when I'm scrolling thru Instagram it lags, or open settings. But i think none of it happens in TugaPower. I have the same apps installed... Can anybody help me please. It usually starts to lag after I installed xposed (even if I don't have any modules installed)
I have tried flashing diff Gapps as well. It still lags. Other users say that the ROM works fine. But not for me. I want to try the other custom Roms as well and see the cool features,etc
Most roms lag even if i dont install xposed...
Tarfex
Ice Cream Sandwich
Apr 12, 2016
Didn't it get discontinued?either way I'll report back and see if this one doesn't lag (doubt it tbh...) :/ idk what's causing it
Tarfex
Ice Cream Sandwich
Apr 12, 2016
OK so I installed xposed and the rom is starting to lag a little bit. I'm going to try the DDR partition thing youbtolf me to do.
Also the laggiest app seems to be goggle play music on all the Roms. It literally takes a minute before it loads everything and becomes useable.
Edit: What are the steps to wipe...DDR partition
Will it it wipe everything on my phone?
