7
Rooted OxygenOS 11 on my OnePlus 7 Pro
  1. Raven6681
    Froyo Apr 7, 2021
    Raven6681 , Apr 7, 2021 :
    with the guide I posted some days ago yes I rooted it
  2. B1617706675331
    Cupcake Apr 8, 2021
    B1617706675331 , Apr 8, 2021 :
    Hello hoow u guys doing??
    I have a OP7tpro on 11 .. can u properly guid me how to root my device?
  3. KenZaki
    Cupcake Apr 10, 2021
  4. Adam_ie
    Cupcake Apr 13, 2021
    Adam_ie , Apr 13, 2021 :
    I followed the guide, but my phone takes a long time to boot, and when it does I have no wifi.
    I'm in EU and I've used the EU version you uploaded but still the same. Not sure what I'm missing?
    Magisk 22.1 (22100) installed, and rooted.
    Android 11, Oxygen OS 11.GM21BA
    I need my phone back working - even unrooted. I tried to flash the stock boot image and still the same issues.
  5. #25
    Adam_ie likes this.
  6. Adam_ie
    Cupcake Apr 14, 2021
    Adam_ie , Apr 14, 2021 :
    Do you have the boot.img you can share? If it's EU?
    I've tried flashing the EU boot.img that was uploaded by kawnoz, but still the same issues persist.
  7. Adam_ie
    Cupcake Apr 15, 2021
    Adam_ie , Apr 15, 2021 :
    Had a remote session with Oneplus and they got me back to stable android 10 using the MSN tool. Mostly driver issues they needed to correct. Think I'll dodge 11 for a while to avoid any more problems!
  8. R1582231263549
    Cupcake Apr 18, 2021
    R1582231263549 , Apr 18, 2021 :
    For those who think they are bricked by booting a twrp image... that is exactly why we boot first, and not flash. Even with a patched boot from inside magisk, I will always "fastboot boot" the image before I "fastboot flash" it. If it doesn't work, reboot and you're fine.
    If you're stuck on a screen with the OP logo and the text "fastboot mode", simply hold vol_up and power until your device reboots.
  9. Ajdi
    Honeycomb Apr 20, 2021
    Ajdi , Apr 20, 2021 :
    So is anyone running OOS 11.0.0.2 successfully on a rooted OnePlus 7 Pro?
  10. ModLife
    Ice Cream Sandwich Apr 21, 2021
    ModLife , Apr 21, 2021 :
    Yes with patched Boot.img
    E1562209091040, dliedke and Ajdi like this.
  11. Ajdi
    Honeycomb Apr 22, 2021
    Ajdi , Apr 22, 2021 :
    Awesome news! Did you dirty flash or clean install?
  12. ModLife
    Ice Cream Sandwich Apr 22, 2021
    dliedke likes this.
  13. jurgencachia
    Cupcake Apr 23, 2021
  14. O1558799435107
    O1558799435107 , Apr 23, 2021 :
    I upgraded to 11.0.2 yesterdayand trying to install Magisk to re-root. I cannot boot to TWRP image from fastboot. running command:
    fastboot boot twrp-3.5.2_9-0-guacamole.img
    The phone just goes to screen "Fastboot mode" and never goes any further.
    Any advice? I had this issue on OxygenOS 10 too and ended up using some modified img of TWRP.
    I'd appreciate help on this! Thanks guys.
  15. dliedke
    Cupcake Apr 24, 2021
    dliedke , Apr 24, 2021 :
    Hello, in order to update One Plus 7 PRO to Android 11 and apply root, I uploaded original and Magisk patched boot images for Oxygen OS 11.0.0.2 GM21AA (Global / India) version at:
    https://drive.google.com/drive/folders/1STUud-d4kv5YLna_a42p-DJCsVGfcGeJ?usp=sharing
    Also added the txt with instructions to install. Worked just fine here.
    Full instructions details:
    1) Download all the files from https://drive.google.com/drive/folders/1STUud-d4kv5YLna_a42p-DJCsVGfcGeJ?usp=sharing
    2) Download OnePlus 7 Pro Oxygen OS 11.0.0.2 GM21AA Global / India firmware update from:
    https://otafsg1.h2os.com/patch/amaz....P.36_OTA_0360_all_2104141852_885ac6583aa.zip
    Source site: https://www.androidsage.com/2021/04...fix-ota-update-for-oneplus-7-7-pro-7t-7t-pro/
    3) Remove Magisk from your phone if you have it.
    4) Install Magisk.22.1.Canary.Android11.apk in your device from downloaded files.
    5) Copy file OnePlus7ProOxygen_21.P.36_GLO_0360_2104141852/OnePlus7ProOxygen_21.P.36_OTA_0360_all_2104141852_885ac6583aa.zip to your device root.
    6) Install new Android 11 firmware image using Settings, System, System update, click on gear on top, local update and select the file.
    It will take some minutes. After complete DO NOT REBOOT.
    7) Make sure you have platform tools (https://androidfilehost.com/?fid=962339331459003166) installed in your PC for adb and fastboot utilities.
    8) Enable developer mode in the device and ADB debugging in your device.
    9) With device connected to the PC via usb cable, in the PC run command:
    adb reboot bootloader
    Wait for fast boot screen in the device. Then run:
    fastboot flash boot OnePlus7Pro.11.0.0.2.GM21AA.magisk_patched_boot.img
    10) Reboot and check if root worked with root checker application:
    https://play.google.com/store/apps/details?id=com.joeykrim.rootcheck
    Some web sites I used for reference and to create the patched magisk boot image (if you have a different version than GM21AA and need to create your image):
    https://www.droidwin.com/fix-magisk-patched-boot-img-issues-android-11/#Android_11_Magisk_patched_Boot_Image_Issue_Fix
    https://www.droidwin.com/extract-stock-boot-img-oneplus-oxygenos-stock-rom/
    https://www.droidwin.com/patch-stock-boot-image-flash-magisk/
    Notice that TWRP 3.5.2 or lower does not work with Android 11.
    Thanks!
    Daniel Liedke
    ModLife likes this.
  16. G1575349825886
    G1575349825886 , Apr 24, 2021 :
    Thanks for the upload, I got this installed on my phone and had wifi and data working! However, I did notice that my basicIntegrity check failed. Would anyone have a potential solution for this?
    dliedke likes this.
  17. dliedke
    Hello, here basicIntegrety and ctsProfile are checking are passing. Try removing your magisk and installing the one I provided in the link https://drive.google.com/drive/folders/1STUud-d4kv5YLna_a42p-DJCsVGfcGeJ?usp=sharing. It was recommended in some website to use the Canary version.
    Thanks!
    Daniel
  18. O1558799435107
    O1558799435107 , Apr 24, 2021 :
    Omg thanks so much for posting this. I will try this asap and let you know my results!
    Have a great weekend!
    #38
    dliedke likes this.
  19. MajinAndy
    MajinAndy , Apr 24, 2021 :
    I tried the exact steps above, but still has the OnePlus slow spinning issue and won't boot up. Is there something I'm missing?
    EDIT: Nevermind, it worked! I just had to use
    "adb wait-for-device shell magisk --remove-modules" after "fastboot flash boot OnePlus7Pro.11.0.0.2.GM21AA.magisk_patched_boot.img"
    Thanks!
    #39
    dliedke likes this.
  20. justinstrack
    Eclair Apr 24, 2021
    justinstrack , Apr 24, 2021 :
    Can someone point me to a video or make a video on how to update to Android 11, with root.
    #40
