10
Rooted OxygenOS 11 on my OnePlus 7 Pro
  1. dliedke
    Eclair Apr 24, 2021
    dliedke , Apr 24, 2021 :
    Great! I hope it works for you! Have a nice weeked as well!
    #41
  2. dliedke
    Eclair Apr 24, 2021
    Hello, there is one video I found:
    but you may also follow the steps I posted in this forum if you have One Plus 7 PRO GM21AA. You may check your version in Settings -> About Device. Thanks!
    #42
  3. justinstrack
    Eclair Apr 24, 2021
    #43
  4. dliedke
    Eclair Apr 24, 2021
    #44
  5. O1558799435107
    Cupcake Apr 26, 2021
    O1558799435107 , Apr 26, 2021 :
    Confirmed this worked. Thanks so much Daniel! Always appreciate the Android community. :)
    #45
    dliedke likes this.
  6. dliedke
    Eclair Apr 26, 2021
    dliedke , Apr 26, 2021 :
    Great news! Happy to help!! 😀
    #46
  7. Aditya Vashishth
    Aditya Vashishth , Apr 26, 2021 :
    hey i am facing the same problem,have you find any solution?
    #47
  8. dliedke
    Eclair Apr 26, 2021
    Can you reboot to system? Using fastboot reboot command?
    #48
  9. dliedke
    Eclair Apr 26, 2021
    No, it doesn't. If TWRP 3.5.2 is run in Android 11 it will be in boot loop flashing the TWRP logo screen. Use power+volume up to reboot.
    #49
  10. Robertmike
    Robertmike , Apr 26, 2021 :
    I had to roll back OS (lost data, but had backup), then followed instructions from post 35......there is a way to keep twrp but involves decrypted phone which is not a good idea. ( google Disable Dm verity from xda).....btw I have loaded canary magisk and can still not pass integrity test any idea's
    nvm I fixed it :)
    #50
  11. JB Petersen
    Cupcake May 5, 2021
    JB Petersen , May 5, 2021 :
    I stopped using twrp all together. Magisk allows for all the rooting solutions to be done, in-app. If you need to do a nandroid backup, go to boot loader and use fastboot boot (name of recovery).img. This is only temporary, until next boot. But you can do the backups etc just fine. If you already have magisk and download the OTA, then use install to inactive slot option BEFORE REBOOTING
    #51
  12. Huntermonk
    Cupcake May 6, 2021
    Huntermonk , May 6, 2021 :
    Eu ja estou na 11.0.0.2 posso instalar o pach ?
    #52
  13. Steps Parku (DJ STEPS)
    Gingerbread May 12, 2021
    #53
  14. Steps Parku (DJ STEPS)
    Steps Parku (DJ STEPS) , May 12, 2021 :
    you might have lost all your data then? is your phone wiped thoroughly?
    #54
  15. MADM03
    Froyo May 14, 2021
    #55
    dliedke likes this.
  16. dliedke
    Eclair May 16, 2021
    dliedke , May 16, 2021 :
    Pode sim, sem problemas, desde que seja o GM21AA
    #56
  17. Adam_ie
    Cupcake May 20, 2021
    Adam_ie , May 20, 2021 :
    Yes totally wiped, but I was fine with that. Just wanted my phone working again.
    #57
  18. R1558142863407
    Cupcake May 23, 2021
    R1558142863407 , May 23, 2021 :
    Patching boot.img through magisk and flashing it via fastboot worked for me, but after reboot the phone Im losing the root.
    am I doing something wrong?
    #58
  19. dliedke
    Eclair May 23, 2021
    dliedke , May 23, 2021 :
    Are you using Magisk.22.1.Canary Release? Please check my guide at page 2. Thanks!
    #59
  20. T1591779015621
    Cupcake May 24, 2021
    T1591779015621 , May 24, 2021 :
    Hi Dliedke,
    Am using GM21AA Indian Version and my phone was rooted earlier in Andriod 10.
    Later i updated it to 11.0.0.2 from automatic update and now i dont have the root access
    As now i already have the Latest Version , I tried to follow your steps from Step 7, but got the error message
    on Step 9 ( fastboot flash boot OnePlus7Pro.11.0.0.2.GM21AA.magisk_patched_boot.img) stating
    "Transfer Failed Too many Links"
    I am just trying to get the root Access again!!!
    I also saw the Youtube video you shared in Thai Language
    Is the boot.img showed in that video , will it fit for GM21AA ?
    #60
