10
Rooted OxygenOS 11 on my OnePlus 7 Pro
  1. T1591779015621
    Cupcake May 24, 2021
  2. dliedke
    Eclair May 25, 2021
    #62
    T1591779015621 likes this.
  3. T1591779015621
    Cupcake May 26, 2021
    T1591779015621 , via OnePlus 7 Pro , May 26, 2021 :
    That's a good finding, Dliedke..but my PC is not old , may be I might have tried in usb 2.0 and I can try now in 3.0..But the question now , we got the update to 11.0.1.1 GM21AA through automatic updates and I have upgraded it. Now will the root procedure be same for this version as well with the files you shared in your post or the Thai video you shared or do we need to wait for a working TWRP??
    #63
    Khaledmayas likes this.
  4. MajinAndy
    Cupcake May 28, 2021
    MajinAndy , May 28, 2021 :
    Is anyone able to provide the 11.0.1.1 GM21AA boot img and the magisk patched here?
    #64
    dliedke likes this.
  5. dliedke
    Eclair May 28, 2021
    dliedke , May 28, 2021 :
    Yes, working on it. Once tested I will post the files here. Thanks!
    #65
  6. dliedke
    Eclair May 28, 2021
    Hello, in order to update One Plus 7 PRO to Android 11 (or update from 11.0.0.2) and apply root, I uploaded original and Magisk patched boot images for Oxygen OS 11.0.1.1 GM21AA (Global / India) version at:
    https://drive.google.com/drive/folders/1STUud-d4kv5YLna_a42p-DJCsVGfcGeJ?usp=sharing (folder OxygenOS 11.0.1.1)
    Also added the txt with instructions to install. Worked just fine here.
    Full instructions details:
    1) Download all the files from https://drive.google.com/drive/folders/1STUud-d4kv5YLna_a42p-DJCsVGfcGeJ?usp=sharing (folder OxygenOS 11.0.1.1)
    2) Download OnePlus 7 Pro Oxygen OS 11.0.1.1 GM21AA Global / India firmware update from:
    https://www.androidsage.com/2021/05/23/download-oxygenos-11-0-1-1/
    3) Remove Magisk from your phone if you have version lower than Magisk.22.1 (Canary release)
    4) Install Magisk.22.1.Canary.Android11.apk in your device from downloaded files.
    5) Copy file OnePlus7ProOxygen_21.P.37_OTA_0370_all_2105200027_0a2b34cb15b36.zip to your device root.
    6) Install new Android 11 version 11.0.1.1 firmware image using Settings, System, System update, click on gear on top, local update and select the file.
    It will take some minutes. After complete DO NOT REBOOT.
    7) Make sure you have platform tools (https://androidfilehost.com/?fid=962339331459003166) installed in your PC for adb and fastboot utilities.
    8) Enable developer mode in the device and ADB debugging in your device.
    9) With device connected to the PC via usb cable, in the PC run command:
    adb reboot bootloader
    Wait for fast boot screen in the device. Then run:
    fastboot flash boot OnePlus7Pro.11.0.1.1.GM21AA.magisk_patched_boot.img
    10) Reboot and check if root worked with root checker application:
    https://play.google.com/store/apps/details?id=com.joeykrim.rootcheck
    Some web sites I used for reference and to create the patched magisk boot image (if you have a different version than GM21AA and need to create your image):
    https://www.droidwin.com/fix-magisk...ndroid_11_Magisk_patched_Boot_Image_Issue_Fix
    https://www.droidwin.com/extract-stock-boot-img-oneplus-oxygenos-stock-rom/
    https://www.droidwin.com/patch-stock-boot-image-flash-magisk/
    Notice that TWRP 3.5.2 or lower does not work with Android 11.
    Remember it is your decision to install software on your device. I take no responsibility for any damage that may occur from following this guide.
    Thanks!
    Daniel Liedke
    #66
    ModLife and Ajdi like this.
  7. ModLife
    Ice Cream Sandwich May 31, 2021
    ModLife , May 31, 2021 :
    Dirty.
    #67
  8. ModLife
    Easy, just use the boot.img methode no time to make a video, sorry.
    - Extract the boot img from the full ota 11.0.1.1
    - Patch the boot img with Magisk
    - Flash it under fastboot mode from PC.
    #68
    dliedke likes this.
  9. Khaledmayas
    Cupcake Jun 1, 2021
    Khaledmayas , Jun 1, 2021 :
    Hi, T1591779015621 have asked a question witch i want to ask too:
    (But the question now , we got the update to 11.0.1.1 GM21AA through automatic updates and I have upgraded it. Now will the root procedure be same for this version as well)
    So will your method still work while we already on OOS 11.0.1.1???? Thanks
    #69
    dliedke likes this.
  10. dliedke
    Eclair Jun 1, 2021
    dliedke , Jun 1, 2021 :
    Yes Khaledmayas, you just need to reboot to bootloader and install the magisk patched boot image. I tested here:
    >fastboot getvar current-slot
    current-slot: b
    Finished. Total time: 0.005s
    Sending 'boot_b' (98304 KB) OKAY [ 2.652s]
    Writing 'boot_b' OKAY [ 0.399s]
    Finished. Total time: 3.114s
    Before this procedure make sure OEM unlocking is enabled and your bootloader is unlocked (step 1 and 2 from guide at https://www.xda-developers.com/unlock-bootloader-root-oneplus-7-pro/).
    Thanks!
    Daniel
    #70
  11. Khaledmayas
    Cupcake Jun 1, 2021
    I've tried to root it before on OOS 1.0.0.2 it did root but I lost Wi-Fi and signal. so i had to install the latest update back. I'm gonna try your method and finger crossed hoping it works. it might sound weird but infect I'm rooting t just to get the AOD working
    #71
  12. dliedke
    Eclair Jun 1, 2021
    dliedke , via OnePlus 7 Pro , Jun 1, 2021 :
    Good luck! No issues with cellphone signal /4G / Wi-Fi here using the procedure. Thanks!
    #72
  13. Khaledmayas
    Cupcake Jun 6, 2021
    #73
    dliedke likes this.
  14. IYampolskyI
    Cupcake Jun 11, 2021
    #74
  15. dliedke
    Eclair Jun 11, 2021
    dliedke , Jun 11, 2021 :
    OnePlus 7 Pro device uses A/B partition schema and you may apply patched magisk boot image to both partitions, but it is not required.
    #75
  16. weakNPCdotCom
    Cupcake Jun 23, 2021
    #76
    dliedke likes this.
  17. dliedke
    Eclair Jun 23, 2021
    #77
  18. Series32
    Cupcake Jun 24, 2021
    Series32 , Jun 24, 2021 :
    can anyone tell me why I can't create a new thread? it says "You do not have permission to view this page or perform this action."
    #78
  19. H1n
    Cupcake Jul 3, 2021
    #79
  20. dliedke
    Eclair Jul 4, 2021
    #80
