Rooted update Help! Power saving
  1. elitekernel
    Gingerbread Aug 23, 2014
    elitekernel , Aug 23, 2014 :
    I have 2 questions
    1. Why do I feel like I'm not getting best out my battery. There probably are more threads about this but, can you guys lmk what processor setting and or any setting that I can use to maximize performance only when the phone needs it.
    2. I rooted my phone using the c4tech tutorial on YouTube, I believe it's TWRP unlocked bootloader and custom recovery, bacon I belive. I did the 33 Ota update and lost root, all I have to do is release the superuser zip right?
  2. jshjx
    Jelly Bean Aug 23, 2014
  3. gatenosix
    KitKat Aug 23, 2014
    gatenosix , Aug 23, 2014 :
    1. Not really sure about this myself.
    2. Yes; just flash the .zip via recovery.
  4. elitekernel
    I hear everyone saying they get 19-24 hours on a charge, I try to take off sync, take off WiFi, bluetooth, took off gestures and double tap to wake and sleep. I can honestly say I get about 9-10.5 hours of using it like that.
  5. elitekernel
  6. housry23
    Ice Cream Sandwich Aug 23, 2014
    housry23 , Aug 23, 2014 :
    That's not enough information. Are you playing games? What's your screen on time? Any music or video streaming, web browsing? You should get more than 10 hours on a full charge but not if your doing heavy intensive things like that.
    Also, I just leave everything alone as far as processor settings and kernel tweaks. Don't mess with those unless you really know what you're doing. The best way to save some battery is to go into location settings and disable location reporting and location history.
  7. abdirahman1995
    Cupcake Aug 23, 2014
  8. elitekernel
    I understand processor settings and clock settings, I know enough to play with what I do know, I just wanted to know if there was a particular setup when it comes to the processor state ( adaptive, conservative etc) combined with either balanced and or performance profile and as you mentioned location settings, to achieve at least a full 20 hour battery time.
  9. vmk2310
    vmk2310 , Aug 23, 2014 :
    Go into TWRP and then reboot to system it will then ask if you want to reroot and click accept. And for battery install franco kernel
  10. vmk2310
    Nope, just clear the cache partition and that's it. Dont factory reset and your done.
  11. vmk2310
    I choose processor "On-Demand" and i/o scheduler to "Deadline" they are pretty efficient and the battery for me lasts about 2 days with 13 hour on screen while listening to music. I highly recommend getting franco kernel as it saves battery and also speeds up charging.
  12. elitekernel
    Okay so I reflash the superuser zip, then clear cache partition, then apply Franco kernel? Can you give me instructions? I do understand the concept and the majority of the process but I just want to ensure my self that I won't screw up my phone, technology has changed since I used to root phones. Thanks
  13. vmk2310
    Sorry for late reply, and yes just get franco kernel r14 zip file for, this is important, CM11s not ASOP. I believe you know what to do.
  14. elitekernel
    Gingerbread Aug 24, 2014
    elitekernel , Aug 24, 2014 :
    okay besides the kernel for now, after the new OTA, just reflash the Superuser zip, and then wiped the cache/dalvik ? All from the bootloader correct ?
  15. elitekernel
    nah no problem, thanks man reflash then wipecache im asssuming.
    vmk2310 likes this.
  16. elitekernel
    i feel like the phone is acting funny, im getting a more force closes, and screen stop responding once or twice after. anything i have to make sure i do ? as in flashing/cleaning/---- really starting to think about reverting now. lol
    @vmk2310
  17. vmk2310
    Jelly Bean Aug 24, 2014
    vmk2310 , Aug 24, 2014 :
    Which OTA did you install and what did you have before?
  18. elitekernel
    i believe i had the r30 ota; i followed steps here and was rooted fine, when the r33 became available, i read to just disable update cm recovery in developer options and install ota regularly. worked fine, thats when i posted this trying to confirm that i had to re flash the superuserzip to regain root. @vmk2310
  19. elitekernel
  20. vmk2310
    Did you wipe dalvik after franco kernel?
