Rooting Discussion
Are going to/Have you already rooted you opo?
  1. Yes.
    56 vote(s)
    72.7%
  2. Nah.
    21 vote(s)
    27.3%
  1. kstaplet
    Ice Cream Sandwich Sep 8, 2014
    kstaplet , Sep 8, 2014 :
    Xposed can help you get around that
  2. mramirkhan
    Honeycomb Sep 8, 2014
    mramirkhan , Sep 8, 2014 :
    Doesn't work, known issue :(
  3. Gx3k
    Eclair Sep 9, 2014
    Gx3k , Sep 9, 2014 :
    Nationwide allows the app to run on rooted phones too.
  4. MoXVII
    Gingerbread Oct 28, 2014
    MoXVII , Oct 28, 2014 :
    Just out of curiosity, why do some of you root in terms of aesthetics and user experience.
    Also how has it affected your battery life?
    Finally recommend me a ROM?
  5. niemancj
    Honeycomb Oct 28, 2014
  6. keessonnema
    KitKat Oct 28, 2014
    keessonnema , Oct 28, 2014 :
    Rooted, mainly because of Xposed :) I always rooted my phones from the beginning (froyo 2.1)
  7. viperex37
    Cupcake Nov 14, 2014
  8. Spritey
    Ice Cream Sandwich Dec 2, 2014
    Spritey , Dec 2, 2014 :
    If you use the search facility (magnifying glass top right) there's loads of help
  9. fazerboy0_3
    Honeycomb Apr 19, 2015
    fazerboy0_3 , Apr 19, 2015 :
    I did and even tried root fake app.. Nope no joy fecking apps..
  10. mramirkhan
    Honeycomb Apr 20, 2015
    mramirkhan , Apr 20, 2015 :
    They use native code to check for root and won't work if detected. So x posed can't help
  11. Majamulli
    KitKat Apr 20, 2015
  12. Adugr8
    Jelly Bean Apr 20, 2015
    Adugr8 , Apr 20, 2015 :
    Check my sig for to root or not to root thread... I think this is duplicate...
  13. imyou
    Eclair Apr 20, 2015
    imyou , Apr 20, 2015 :
    im new to this rooting phone thing, what is rooting on opo? and what does it do for the phone?
  14. 0xFFFFail
    Eclair Apr 20, 2015
    0xFFFFail , Apr 20, 2015 :
    My OPO on lollipop refuses to realise it's rooted.I clean installed cm12s and then the first thing I did was install supersu, currently no app recognises root apart from root checker and supersu which crashed when I try to update the root binary.
  15. NickSalonika
    Gingerbread Apr 20, 2015
    NickSalonika , Apr 20, 2015 :
    ROOT IS LOVE, ROOT IS LIFE.
    Root shouldn't affect battery life. I recommend Exodus, but my personal opinion is to try many roms and see which one suits you.
    It basically unlocks many features of the phone. You can use it to change everything on the phone from the rom (basically OS) to the sound settings...
    shobe338 likes this.
  16. shobe338
    shobe338 , Apr 20, 2015 :
    I've rooted several phones before to remove bloatware. Yesterday I took the next step and loaded exodus onto my OnePlus One. I got tired of waiting for the OTA for lollipop. Now it works better than ever and my battery life is awesome!
    bakerbarber likes this.
  17. gedeone
    Ice Cream Sandwich Apr 20, 2015
  18. Wrjeffers10
    Cupcake Apr 20, 2015
    Wrjeffers10 , Apr 20, 2015 :
    I am having this exact same problem. In the dev options, where "root access" used to be now says "cyanogen recovery" and I no longer have TWRP.
    #38
  19. imyou
    Eclair Apr 20, 2015
    It basically unlocks many features of the phone. You can use it to change everything on the phone from the rom (basically OS) to the sound settings...[/QUOTE]
    ooh so thats what it does, if i do want to root opo soon-to-be, what do i need to know?
    #39
  20. 0xFFFFail
    Eclair Apr 20, 2015
    I never even had that option, just this problem :/
    Also does anyone know how to make a VPN app work on cm12s? It refuses to key me press OK to trust a VPN request from the app
    #40
