2
RR (N) Latest Build For OP2
  1. pryggi Ice Cream Sandwich Jun 2, 2017
    pryggi, Jun 2, 2017 :
    The unofficial RR from SONI has opendelta ota updates, so no need to dl the +500mb zips. Everything is automatic, downloads the incremental update zip, merges this into the last full +500mb zip, boots to twrp, creates a backup if you want, flashes the updated full zip, flashes any other zips, like oos cam, and reboots system.
    More info here:
    https://forum.xda-developers.com/showpost.php?p=70080016&postcount=4
    #81
  2. nelson pansare Ice Cream Sandwich Jun 2, 2017
    nelson pansare, Jun 2, 2017 :
    Is there anyone facing the problem with ambient screen....? I have enabled everything like hand wave and all..but still its nit working..! it works on oxygen os but not on any other rom...!
    #82
    mickey840 likes this.
  3. nash122 Cupcake Jun 2, 2017
    nash122, Jun 2, 2017 :
    Unable to connect my device to PC. Tried changing to MTP in developer options but still no luck. Third party apps like shareit is also unable to connect to PC. Any solutions?
    #83
  4. Imrsofficial Froyo Jun 3, 2017
    Imrsofficial, Jun 3, 2017 :
    bro what's that error m not able to use my finger print tried looking for the solution on xda but nothing worked
    #84
  5. mickey840 Ice Cream Sandwich Jun 3, 2017
    mickey840, Jun 3, 2017 :
    clean install the rom!;
    #85
    Imrsofficial likes this.
  6. Imrsofficial Froyo Jun 3, 2017
    #86
  7. cirillo30 Froyo Jun 5, 2017
    cirillo30, Jun 5, 2017 :
    i have drop connections with last build. Any idea?
    #87
  8. mickey840 Ice Cream Sandwich Jun 5, 2017
    mickey840, Jun 5, 2017 :
    disable google contact app!
    #88
    cirillo30 likes this.
  9. cirillo30 Froyo Jun 5, 2017
    thanks. This bug will be correct?
    #89
  10. mickey840 Ice Cream Sandwich Jun 5, 2017
    #90
  11. jsb007 Gingerbread Jun 5, 2017
    #91
  12. cirillo30 Froyo Jun 7, 2017
    #92
