Running applications are crashed. via OnePlus 8
  1. P1609505538462
    Cupcake May 14, 2021
    P1609505538462 , via OnePlus 8 , May 14, 2021 :
    This is to inform that while using an application suddenly it get crashed and popped up a notification as mentioned below. This is the scenario I found for many applications.. PFA.
    Below mentioned activities are verified.
    1. Android system webview verified.
    2. Have enough RAM availability.
    3. System update has been verified.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 May 15, 2021
    Dresa91 , May 15, 2021 :
    Did you clear cache and data of Amazon Prime Video?
  3. P1609505538462
    Cupcake May 16, 2021
    P1609505538462 , via OnePlus 8 , May 16, 2021 :
    Thanks for your response. Yes, I have cleared both cache and data but this is not the issue alone with prime application. I can see many of the applications are crashed.
  4. Dresa91
    User of the Year 2016; Most Active User 2020 May 16, 2021
    Dresa91 , May 16, 2021 :
    Did you update the app Android System WebView?
  5. P1609505538462
    Yes this has been already updated in my phone.. I have checked all the possibilities.
    Did you know any other persons report the same ?
  6. Dresa91
    Did you clear cache in recovery?
    did you report it via https://forums.oneplus.com/feedback/?
  7. P1609505538462
  8. P1609505538462
  9. Dresa91
    Can you please also clear cache and data of WebView app?
  10. P1609505538462
    Yes I have cleared... I already done all the possibilities which I get from Google... Seems like It happens randomly not in daily basis. Why should I do the same troubleshooting in all the time.
  11. Dresa91
    then please wait for the response of the dev team
  12. P1609505538462
  13. Dresa91
    Yeah:) you are welcome:)
  14. Roxtarritesh
    Eclair May 17, 2021
  15. P1609505538462
    Cupcake May 17, 2021
  16. Roxtarritesh
    Eclair May 17, 2021
  17. Sidharth0628
    Froyo May 19, 2021
