6
Running (well more like jogging)
  1. Lizzie232
    Gingerbread Aug 29, 2014
    Lizzie232 , Aug 29, 2014 :
    Thanks for all your replies, I shall most definitely have a look at the bands/ earphones recommended :)
    #41
  2. chongswee
    Jelly Bean Aug 29, 2014
    #42
  3. Ajey
    Ajey , Aug 29, 2014 :
    Happy running !
    #43
  4. omarsoneplusone
    Gingerbread Sep 2, 2014
    omarsoneplusone , Sep 2, 2014 :
    The in ear ones give better sound but arent as comfortable as the over the ear ones( especially on a warm day) . The over the ear ones dont have the best sound(more background noise) but thats a good thing especially if you're jogging and need to be as aware as possible. I'd say go with over ear headphones.
    #44
  5. yellowtwice
    Honeycomb Sep 2, 2014
    yellowtwice , Sep 2, 2014 :
    I like running with Koss Porta Pro. They do not slip out of your ears and they provide good sound quality. Sort of.. if you like bass. :)
    #45
  6. leadeel
    leadeel , Sep 2, 2014 :
    Don't jog with headphones. My opinion. Not particularly safe - I hate dodging walkers and runners that can't hear your horn or you shouting "coming up" on your bike and then they dart over and nearly cause you to wipe out.
    #46
  7. jayarh
    jayarh , Sep 2, 2014 :
    I second these, and they'll never fall out of your ears
    #47
  8. GTOwner
    Froyo Sep 10, 2014
    GTOwner , Sep 10, 2014 :
    This thread passed from discussing armbands to headsets...Anyone found a good armband besides the kwmobile?
    #48
  9. zt4949
    Froyo Sep 11, 2014
    zt4949 , Sep 11, 2014 :
    I'm in the same boat. Only when I go running, I have to hold the phone and the earbuds fall out about every quarter mile.
    #49
  10. JosiahSnarr
    Gingerbread Sep 11, 2014
    JosiahSnarr , Sep 11, 2014 :
    Not sure how well all sony in-ears are, but I've never been disappointed with using sony in-ear headpones while running. I've had the same headphones falling out problem with every other pair I've ever had, but I've had 3 pairs of sony in-ears that haven't failed me. Again I haven't used the widest range of headphones, so take that with a grain of salt.
    #50
  11. Zachsaxe
    Lollipop Sep 11, 2014
    Zachsaxe , Sep 11, 2014 :
    Who needs a arm band with Bluetooth headphones I recommend the Jay bird bluebuds x. But I also heard duct tape works. No seriously make a duck tape one with either a screen cut out or plastic
    #51
  12. GTOwner
    Froyo Sep 11, 2014
    GTOwner , Sep 11, 2014 :
    Whether you choose to use standard headphones or bluetooth headphones, you still need something to carry your phone and a couple of keys (house and/or car). That's why I was asking about an armband...
    I had a look at the SPIbelts and they're quite nice, but since I don't have problems with my in-ear a-JAYS Three I would avoid spending 30-40€ for bluetooth headphones I don't really need. Therefore, my only choice is an armband if I want to change song or adjust the volume while running.
    #52
  13. Kazua
    Kazua , Sep 11, 2014 :
    good headphones for running :-
    Sennheiser PMX 685i Sports
    Review:
    http://www.trustedreviews.com/best-headphones-for-running_round-up_Page-5
    Buy:
    http://www.amazon.co.uk/Sennheiser-PMX-685i-Neckband-Headphones-Black/dp/B0094R4Q6Y
    #53
  14. Padraig22
    Cupcake Sep 11, 2014
    Padraig22 , Sep 11, 2014 :
    I use just normal headphones and don't turn out off my ear^^ The in-Ear ones makes a bad feeling inthe ears. And it makes a border between you and the world around you.
    But i guess that the Problem with an armband is, that the cable is very uncomfortable. If you hab bluetooth Headohones it would be better, of course ;)
    #54
  15. GTOwner
    Froyo Sep 12, 2014
    GTOwner , Sep 12, 2014 :
    I finally bought the kwmobile armband...I wasn't so sure about it, but it was 4.90€ on Amazon so I just pulled the trigger...I'll let you know my 2 cents when I get it if there's still someone interested
    #55
  16. JakobRosenberg
    Ice Cream Sandwich Sep 12, 2014
  17. MeanBoss
    Cupcake Sep 12, 2014
    MeanBoss , Sep 12, 2014 :
    opo and all other phablets are usless for running ...too large,and uncomfortable...for running i use iphone4,griffin armband and scull candy in ear headphonea(perfect combo)!
    #57
  18. GTOwner
    Froyo Sep 13, 2014
    GTOwner , Sep 13, 2014 :
    Dude, when you have it in an armband what difference doest it make? Are you really saying you feel a difference if the phone is 3 cm longer and 30 g havier on your shoulder??
    #58
    tastesawesome likes this.
  19. geedog
    Donut Sep 13, 2014
    geedog , Sep 13, 2014 :
    I love to run with my phone. I never really got on with the arm bands. You can get running shorts with small zip up pockets at the back which generally do the trick. I have Karrimor shorts which all seem to have pockets. I managed to squeeze a Galaxy note in so a One plus One should work fine.
    #59
  20. fanefane
    KitKat Sep 28, 2014
    fanefane , Sep 28, 2014 :
    i have this armband : the opo fits inside almost perfectly. The only con is the quality of the armband, it doesn't seem very "strong", i think it will be destroyed in less than a year...
    and the other bad things for girls or men with small (thin) arms : the opo is bigger than my arm so it moves around it when i run..
    #60
    Wouter1985 likes this.
