112
Sailfish OS for OnePlus One
Will you flash Sailfish OS?
  1. Yes
    890 vote(s)
    39.9%
  2. No
    459 vote(s)
    20.6%
  3. May be, when it is stable enough.
    879 vote(s)
    39.5%
  1. inDAcore
    Eclair Feb 14, 2016
    inDAcore , Feb 14, 2016 :
    Great work @ruedigergad! Thanks!
    I installed you package and after that I was able to watch Youtube videos with Jolla browser! :)
    (but Not with Webcat or web-pirate). Also Ytplayer did not show videos.
    Then I tried to install again:
    gst-plugins-bad-extra-1.4.5-1.armv7hl.rpm
    gst-plugins-ugly-1.4.5-1.armv7hl.rpm
    But install of these packages fails from warehouse.
    Then I installed:
    gstreamer0.10
    and then installing:
    and then install of these packet were succesfull
    Some of the Ytplayer videos are workign? Should all work?
    This was with quick test. Jolla browser with Youtube work now for me!
    Thanks for you work!
    Edit:
    Some of the YTplayer videos are working after packages have been installed.
    Interesting "bug" is that ytplayer and media app - texts brake after watching some videos.
    aironeous and ruedigergad like this.
  2. ruedigergad
    Donut Feb 14, 2016
    ruedigergad , Feb 14, 2016 :
    Thanks a lot for the feedback.
    Just another very brief reply:
    These are the gstreamer1.0 related packages I have installed:
    [root@localhost nemo]# pkcon search name gstreamer1.0 | grep -Ev "source|debug"
    Transaction: Searching by name
    Status: Waiting in queue
    Status: Starting
    Status: Refreshing software list
    Percentage: 0
    Status: Querying
    Results:
    Installed gstreamer1.0-1.4.5+git1-1.3.3.armv7hl
    Available gstreamer1.0-devel-1.4.5+git1-1.3.3.armv7hl
    Installed gstreamer1.0-libav-1.4.5-1.armv7hl
    Available gstreamer1.0-libav-1.4.5+git2-1.3.2.armv7hl
    Installed gstreamer1.0-plugins-bad-1.4.5+git9-1.9.1.armv7hl
    Available gstreamer1.0-plugins-bad-devel-1.4.5+git9-1.9.1.armv7hl
    Installed gstreamer1.0-plugins-base-1.4.5+git1-1.3.3.armv7hl
    Available gstreamer1.0-plugins-base-apps-1.4.5+git1-1.3.3.armv7hl
    Available gstreamer1.0-plugins-base-devel-1.4.5+git1-1.3.3.armv7hl
    Installed gstreamer1.0-plugins-good-1.4.5+git9.1-1.5.1.armv7hl
    Installed gstreamer1.0-tools-1.4.5+git1-1.3.3.armv7hl
    Installed nemo-gstreamer1.0-interfaces-0.20150126.0-1.1.3.armv7hl
    Available nemo-gstreamer1.0-interfaces-devel-0.20150126.0-1.1.3.armv7hl
    You can use the command above to see if you have them installed and try "pkcon install ..." to install the other packages if some of them are missing.
    IIrc, I had to install some of them manually.
    Furthermore, it would be great if you could upload the output of running "GST_DEBUG=4 harbour-ytplayer", e.g., so "GST_DEBUG=4 harbour-ytplayer &> ytplayer_gstreamer_debug_output.txt" to, e.g., pastebin or so.
    There is no need for a long test, just start ytplayer like this and try to play the first video that is not working.
    Then wait a few seconds and kill/close ytplayer.
    With respect to the font issue:
    Yes, I see this as well.
    aironeous and msri3here like this.
  3. inDAcore
    Eclair Feb 14, 2016
    These packages I have (without yet adding any):
    [nemo@localhost ~]$ pkcon search name gstreamer1.0 | grep -Ev "source|debug"
    Status: Starting
    Percentage: 0
    Status: Querying
    Results:
    Available gstreamer1.0-tools-1.4.5+git1-1.3.3.armv7hl
    So It seems that I am missing this package:
    Installed gstreamer1.0-droid-0.20151215.0-10.26.1.jolla.armv7hl
    And here is that YTPlayer debug. I searched "Foo Fighters" and tried to play first song "Pretender"
    http://pastebin.com/bLCAV7u3
  4. ruedigergad
    Donut Feb 14, 2016
    Thanks for the detailed report @inDAcore.
    Regarding your problem:
    According to the output, the problem seems to be unrelated to the codecs?
    I think the relevant information is from line 184 on:
    "[C] YTVideoUrlFetcher:nProcessFinished:165 - YouTubeDL process did not finish cleanly: "WARNING: Assuming --restrict-filenames since file system encoding cannot encode all characters. Set the LC_ALL environment variable to fix this.
    Regarding gstreamer1.0-droid:
    Sorry, that was misleading.
    This was a left over of one of my experiments during which I installed that from another repository and ignored missing dependencies.
    I edited my post above and removed this package to avoid further confusion.
    gstreamer1.0-droid may become relevant again for hardware accelerated playback but this requires more work on the hardware adaptation side.
    My understanding is that until the required parts become available in the hardware adaptation, gstreamer1.0-droid will not be provided.
    Another point to keep in mind is that once gstreamer1.0-droid or something similar, providing hardware accelerated h264 decoding, becomes available, the gstreamer-libav package provided by me should likely be replaced with the stock version in order to assure that the hardware accelerated decoder is used and not the software-based.
    msri3here likes this.
  5. baddea14
    Gingerbread Feb 14, 2016
  6. inDAcore
    Eclair Feb 15, 2016
  7. Tuski1998
    Eclair Feb 15, 2016
    Tuski1998 , Feb 15, 2016 :
    Hey my sailfish is sucessfully installed but it does not boot . I am on oneplus one bacon with recovery twrp v3.0.0-0 . Is there a recovery problem ?do I need to install twrp 2.8.7.0 plzz help
  8. frederikkamph
    Gingerbread Feb 15, 2016
    vgrade likes this.
  9. mvmsaikrishna
    Ice Cream Sandwich Feb 15, 2016
    mvmsaikrishna , Feb 15, 2016 :
    what is your primary rom?
  10. mvmsaikrishna
  11. baddea14
    baddea14 , Feb 15, 2016 :
    yes it work fine i testing youtube note that web browser hang and freeze after install codecs so it need to reboot device , i hope that all user enjoy with updates big thanks for all ...
    mvmsaikrishna likes this.
  12. mvmsaikrishna
    @Technics you can may be add this to your site
    vgrade likes this.
  13. vgrade
    Honeycomb Feb 15, 2016
    vgrade , Feb 15, 2016 :
    I don't have a 1+2
    vgrade
    frederikkamph likes this.
  14. frederikkamph
    Gingerbread Feb 16, 2016
    vgrade likes this.
  15. michdeskunk
    michdeskunk , Feb 16, 2016 :
    good work!
    When you will fix camera issue let me know! :D
    vgrade likes this.
  16. vgrade
    Honeycomb Feb 16, 2016
  17. inDAcore
    Eclair Feb 16, 2016
  18. vgrade
  19. inDAcore
    Eclair Feb 16, 2016
    inDAcore , Feb 16, 2016 :
    find . -name pre-user-session.target
    cat ./usr/lib/systemd/user/pre-user-session.target
    cd ./usr/lib/systemd/user/
    cp pre-user-session.target pre-user-session.target.bakup
    nano pre-user-session.target
    +modify and save
    [root@localhost /]# cat ./usr/lib/systemd/user/pre-user-session.target
    # pre-user-session.target - a virtual middleware target
    # This happens before user-session
    [Unit]
    Description=Pre user session
    After=ofono.service
    Requires=dbus.socket
    AllowIsolate=yes
    And then I restarted phone and waited it to come up again.
    But I did not find any changed with mobiledata?
    I had to "devel-su systemctl restart statefs" to see 3g signal indacation.
    I did not find mobile settings from Settings or quick view?
    Only after "dconf reset /apps/jolla-settings/maskedSettings" I can see mobile-data related issues.
    Is that "After=ofono.service" in correct place?
  20. VeryMilan
    VeryMilan , Feb 16, 2016 :
    Sorry for the delay.
    I just added this and the apn permission thing to the page :)
    The german translation should follow in the next minutes...
    msri3here and mvmsaikrishna like this.
