112
Sailfish OS for OnePlus One
Will you flash Sailfish OS?
  1. Yes
    890 vote(s)
    39.9%
  2. No
    459 vote(s)
    20.6%
  3. May be, when it is stable enough.
    879 vote(s)
    39.5%
  1. ilovric
    Eclair Jan 17, 2016
    ilovric , Jan 17, 2016 :
    Confirming that mp3 playback works after installing gstreamer libraries.
    pkcon install gstreamer1.0-libav
    Couple of things that need some more treatment are camera, gps, some sensors, official store and battery performance.
    Thank you everyone for your contributions!
    Also find some screenshots attached.
    Screenshot-16-01-17-09-57-06.png Screenshot-16-01-17-09-55-44.png Screenshot-16-01-17-09-58-23.png
    EDIT: just noticed, youtube videos are black while watching with Jolla web browser, but sound is ok.
    Hex and vgrade like this.
  2. vgrade
    Honeycomb Jan 17, 2016
    vgrade , Jan 17, 2016 :
    Working on camera now, we had it working on the last port last year so hopes are high.
    RE android apps and play store have a look at this it might blow you mind and should also be possible.
    vgrade
    PS. keep those screen shots coming
  3. killer.shubham
    Froyo Jan 17, 2016
    killer.shubham , Jan 17, 2016 :
    Working well installed warehouse , though i have some problem with internet , in wifi settings i am able to set proxy though my proxy is 1.1.1.1 (example) and i have to enter it like http://1.1.1.1 otherwise it doesn't allow , then browser is working fine but i cannot add any account neither jolla nor google it says not able to connect
  4. daanw
    Froyo Jan 17, 2016
    daanw , Jan 17, 2016 :
    @vgrade, thank you for this rom, its awesome. it didnt freeze or reboot once since first install. Battery is good, with normal use it should be able to get through the day.
    i feel no reason to switch back to android atm. ;)
  5. Hex
    Donut Jan 17, 2016
    Hex , Jan 17, 2016 :
    Will check the YouTube videos.
  6. vgrade
    Does this sound like your issue ?
    https://together.jolla.com/question/22824/proxy-settings-arent-honoured/
    If so its a general Sailfish issue not related to the port.
    vgrade
    killer.shubham likes this.
  7. iker_92
    Gingerbread Jan 17, 2016
    iker_92 , Jan 17, 2016 :
    sim not recognized for me..chinese 64 OPO..installed fine. i m on h3g network if it can help..i did the command sytemclt ecc but nothing
    EDIT i have to flash lollipop modem, i was coming from marshmallow
    vgrade likes this.
  8. vgrade
    Could you post some logs after adding -d to ofono command in
    /lib/systemd/system/ofono.service
    reboot then collect journal log with
    devel-su
    journalctl
    vgrade
  9. iker_92
    sorry i didn't get it well. terminal says that ofono is not a command. Now i'm in /lib/systemd/system folder in terminal.what i have to do?
  10. vgrade
    So working for you now?
    vgrade
  11. iker_92
    sadly this was not the problem..in cm rom also there is no network..i think that i have to flash lollipop modem in twrp 2.8.6.0, otherwise no modem parts is flashed.now i can't do this but i will try later.
  12. Hex
    Donut Jan 17, 2016
    Had same issue, had to downgrade to 2.8.6.0 too, then I could flash CM13, this had nothing to do with Sailfish but it is a bug in TWRP2.8.6.1 and up
    iker_92 likes this.
  13. vgrade
    try https://openrepos.net/content/cfr34k/messwerk for sensor feedback
    vgrade
  14. killer.shubham
    Froyo Jan 17, 2016
  15. vgrade
    Please vote up the issue on TJC
    vgrade
  16. baddea14
  17. vgrade
    I don't have 4G access here so can't test
    vgrade
  18. luxuskamel
    Marshmallow Jan 17, 2016
  19. Nimeni
    Cupcake Jan 17, 2016
    luxuskamel likes this.
  20. vgrade
    jartometienen and luxuskamel like this.
