112
Sailfish OS for OnePlus One
Will you flash Sailfish OS?
  1. Yes
    890 vote(s)
    39.9%
  2. No
    459 vote(s)
    20.6%
  3. May be, when it is stable enough.
    879 vote(s)
    39.5%
  1. Sanjoov
    Gingerbread Jan 17, 2016
    Sanjoov , Jan 17, 2016 :
    Installed with Multirom. No probs. Booted OK.
    Wifi OK.
    Calling and receiving is OK.
    Using recommended steps in above posts and guides, able to restore network signal om top right.
    However get fatal error in Terminal during installation of Warehouse.
    Like the UI and smoothness though.
    Hope to understand the OS gradually and its nuances.
    Detailed procedures or references appreciated.
    Especially for noobs like me.
  2. vgrade
    Honeycomb Jan 17, 2016
    vgrade , Jan 17, 2016 :
    Thanks for the feedback, good to hear about your progress,
    Hex posted some instructions a few posts back for warehouse so maybe have a look and try again.
    https://together.jolla.com/questions/ is a good resource
    BR
    vgrade
    Sanjoov likes this.
  3. Sanjoov
  4. Mystel
    Eclair Jan 17, 2016
  5. sathish D C
    sathish D C , Jan 17, 2016 :
    @vgrade It need to be install with multirom or can I flash over the cm12.1 without multirom. Is there a way to install this Rom for daily driver
  6. ilovric
    Eclair Jan 17, 2016
    ilovric , Jan 17, 2016 :
    Thanks, vgrade!
    Confirming working sensors:
    - Proximity and brightness
    - Magnetometer
    - Gyro
    - Accelerometer
    - Rotation X and Y axis ok, Z axis not detected
    I see you guys already updated compat table, great! :)
    https://wiki.merproject.org/wiki/Adaptations/libhybris
    Looking through this table, but dont see that LED seems to be working in this release.
    I also tried to trigger NFC event with NFC card, but nothing, also nothing logged in "journalctl -af".
    Question is how can I test NFC?
    Screenshot-16-01-17-16-21-55.png Screenshot-16-01-17-16-22-05.png Screenshot-16-01-17-16-22-15.png Screenshot-16-01-17-16-22-24.png Screenshot-16-01-17-16-22-37.png
  7. vgrade
    Yes, can be flashed over cm12.1 without mutirom, Hex runs it that way. I prefer multirom as it allows me to juggle multiple versions.
    vgrade
  8. vgrade
  9. vgrade
    Thanks, good spot on LED, was working in last port, must have regressed since. I'll have a look
    Jolla has limited NFC for TOH detection but I'm not sure of the support from the ported devices. Its enabled in the kernel https://github.com/smokku/android_k...arm/configs/cyanogenmod_bacon_defconfig#L1225 so you should be able to access using some sort of linux NFC middleware. Have a google around and join us in #sailfishos-porters IRC channel.
    vgrade
    ilovric likes this.
  10. mvmsaikrishna
    Ice Cream Sandwich Jan 17, 2016
    CBpbxEcmecmBeH, luxuskamel and vgrade like this.
  11. Thangarun15
    Cupcake Jan 17, 2016
    Thangarun15 , Jan 17, 2016 :
    Thanks a lot :)
  12. jeffhoogland
    jeffhoogland , Jan 17, 2016 :
    Has anyone gotten mobile data working with TMobile in the US? Calls / texting works well - but the mobile access point can't connect regardless of the settings I try.
  13. msri3here
    msri3here , Jan 17, 2016 :
    I had this problem too, but realized that my apn settings were wrong.
    check and correct them as posted in this guide
  14. akikk88
  15. Dr.Electronic
    Eclair Jan 17, 2016
  16. vgrade
    Dr.Electronic likes this.
  17. bpeeters
    Donut Jan 17, 2016
    bpeeters , Jan 17, 2016 :
    thank you for the work @vgrade !
    so far:
    - camera not yet working (not a big problem for daily use)
    - youtube video doesn't work (though audio does), installing codec pack doesn't fix this
    - had 1 random reboot (doubt it's related to the port, since i experienced it now and then in android roms as well)
    - battery life, on first sight, seems to be worse than exodus rom
    - rotation seems like it doesn't always work
    - waking screen (when covering/uncovering light sensor) seems buggy
    - gps issues(? - can't seem to find the sailfish-maps package anywhere)
    haven't had enough time to completely evaluate, but it does seem good enough for a daily driver..
    and i must say, i'm loving it :)
    a big thanks again to @vgrade and all the porters!
    norman789, Dr.Electronic and vgrade like this.
  18. Dr.Electronic
    Eclair Jan 17, 2016
    Dr.Electronic , Jan 17, 2016 :
    Which phone should I buy ? Anytime I want to use sailfih .
    Jolla
    OnePlus One (multirom; Android, Ubuntu, Sailfish, Miui)
    Fairphone 2
    Intex February 2016 at MWC16 Barcelona
  19. vgrade
    Was fixed with APN , fast.t-mobile.com
    vgrade
  20. bpeeters
    Donut Jan 17, 2016
    @vgrade: noticed a bug that might be a joy-killer: calls don't seem to support dtmf (i.e: you can't get anywhere if you call into an ivr and have a selection menu
