112
Sailfish OS for OnePlus One
Will you flash Sailfish OS?
  1. Yes
    890 vote(s)
    39.9%
  2. No
    459 vote(s)
    20.6%
  3. May be, when it is stable enough.
    879 vote(s)
    39.5%
  1. vgrade
    Honeycomb Jan 17, 2016
    vgrade , Jan 17, 2016 :
    I was able to navigate EE 150 menus,
    vgrade
  2. bpeeters
    Donut Jan 17, 2016
    bpeeters , Jan 17, 2016 :
    @vgrade: strange.. i tested 4 times (numbers 1 and 4 being the same) and it failed only the first 2 times... gonna keep an eye out for 'weird things', but so far i'm quite impressed with sailfish :) it's the perfect marriage: the oneplus one and sailfish
    vgrade likes this.
  3. lozo2010
    Eclair Jan 18, 2016
    vgrade likes this.
  4. trickyhurl
    Cupcake Jan 18, 2016
    trickyhurl , Jan 18, 2016 :
    This is great, thank you! curious...no jolla store? (i installed warehouse, just curious about store)
    Thanks again for this, very smooth nice UI
    edit: i found how to access app store...sorry!
    vgrade likes this.
  5. sathish D C
    Gingerbread Jan 18, 2016
    vgrade likes this.
  6. Hex
    Donut Jan 18, 2016
    Hex , Jan 18, 2016 :
    Screenshots can be taken using the Command grabscreen via SSH, sathish D C, Just add ZIP files
    1. CM12.1
    2. SailfishOS
    3. Swipe to install!
    Wait and it will be finished :)
    vgrade likes this.
  7. CesarOPO
    Eclair Jan 18, 2016
    CesarOPO , Jan 18, 2016 :
    Question: i'm about to install SailfishOS as secondary rom, my primary rom is SlimSaber 5.1.1 CAF with AK CAF kernel.. Will i have issues being my primary ROM CAF based? Does it need to be CM based the primary ROM? I read on the installation instructions AK CM kernel, didn't know if that implies that the primary ROM needs to be CM based... Waiting for confirmation to begin installation. Thanks!
  8. vgrade
    Honeycomb Jan 18, 2016
    vgrade , Jan 18, 2016 :
    We utilise the android drivers in SailfishOS and build against a specific version in this case CM. You may be lucky that the interfaces are unchanged.
    Give it a go and let us know, that's the beauty of multirom.
    BR
    Martin
    mvmsaikrishna and Aukdrck like this.
  9. iker_92
    iker_92 , Jan 18, 2016 :
    flashed cm 12.1 in twrp 2.8.6.0 and then twrp-multirom and all went good. 4g signal :D now i wait for a complete avaiale jolla store and sailfish can be my daily driver ;)
    vgrade likes this.
  10. ilovric
    Eclair Jan 18, 2016
    ilovric , Jan 18, 2016 :
    looking after idle battery drain.
    Turned off all the synching on accounts and battery went down around 18% in 6 hours during night.
    Is it normal that "iw dev wlan0 get power_save" returns "off"?
    Also, is it normal that multicore power saving is set to "0" in /sys/devices/system/cpu/sched_mc_power_savings?
    Turned both of them on and will report after some time.
    Regards,
    I
  11. vgrade
    We've seen issues before, https://forums.oneplus.net/threads/sailfish-os-for-oneplus-one.279537/page-50#post-10807397
    May be the same issue.
    Can't test till later
    BR
    vgrade
  12. ilovric
    Eclair Jan 18, 2016
    Thanks for reply!
    This is current state of governor:
    [root@localhost nemo]# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver
    msm
    [root@localhost nemo]# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    interactive
    [root@localhost nemo]# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
    2457600
    [root@localhost nemo]# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
    300000
    [root@localhost nemo]# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
    interactive conservative ondemand userspace powersave performance
    So, it is set to "interactive" which is fine.
    vgrade likes this.
  13. lozo2010
    Eclair Jan 18, 2016
    vgrade likes this.
  14. vgrade
  15. daanw
    Froyo Jan 18, 2016
  16. horst58
    horst58 , Jan 18, 2016 :
    Try this:
    systemctl restart ohmd.service
    daanw and vgrade like this.
  17. horst58
    Could someone please post content of /etc/fstab? I possibly messed something up :(
  18. rajaspardeshi
    Ice Cream Sandwich Jan 18, 2016
    rajaspardeshi , Jan 18, 2016 :
    Will there be any problems if I install SFOS over a marshmallow ROM via MultiRom? How much of a daily driver is the port?
  19. vgrade
    Give it a try, you may need to reflash modem back to 12.1 in primary rom
    I'll let others comment on daily driver, I have it with me today :) along with the Nexus 5 Sailfish
    BR
    vgrade
    rajaspardeshi likes this.
  20. rajaspardeshi
    I'm quite a newbie when it comes to stuff other than basic ROM flashing, i.e, firmware files/modem. So what you're saying is, if it doesn't work, I'll have to flash cm12.1 as primary and then SOFS?
