112
Sailfish OS for OnePlus One
Will you flash Sailfish OS?
  1. Yes
    889 vote(s)
    39.9%
  2. No
    459 vote(s)
    20.6%
  3. May be, when it is stable enough.
    879 vote(s)
    39.5%
  1. mvmsaikrishna
    Ice Cream Sandwich Jan 20, 2016
    mvmsaikrishna , Jan 20, 2016 :
    Sure.. Let us know if it worked for you!
  2. mvmsaikrishna
    That's so nice of you.. Thanks!
    VeryMilan likes this.
  3. Logan_Adams
    Gingerbread Jan 20, 2016
    Logan_Adams , Jan 20, 2016 :
    One question: Is it normal that downloading apps from the store is not possible (Wifi Connection works).
    Greetz
  4. baddea14
    baddea14 , Jan 20, 2016 :
    i try access to 4G mobile data in image for @vgrade it work fine but it is very slowly to loading web page as example youtube and other web site , i make many testing with ubuntu touch and sailfish the result that i have ubuntu touch faster than sailfish os 2 in 4g mobile data there two something that can sharing it is tweak the mobile data services from @vgrade or waiting for native updates from jolla to fix this bugs .if you check network configuration in mobile data you can see 3g- and -2g only i think these information most be sharing it can helping to tweak and improve next updates for image or release for sailfish os ..
  5. jeffhoogland
    Cupcake Jan 20, 2016
    vgrade likes this.
  6. VeryMilan
    Honeycomb Jan 20, 2016
    VeryMilan , Jan 20, 2016 :
    Here you have some Screenshot of the coming Page... still waiting for Feedback from Hex.
    Maybe something optical will change in the future...but the "base" stay so.
    Hope you like it.
    Edit: this is really a base look with this screenshottet part, but if you have any ideas to improve the page, please tell me :)
    Edit2: aaw, nice, now the <code> have its colourset :)
    Edit3: Hex gave green light
    rajaspardeshi, mvmsaikrishna and Hex like this.
  7. Sudheer4188
    Eclair Jan 20, 2016
    Sudheer4188 , Jan 20, 2016 :
    hi...first of all a big thanks to the developer @vgrade for developing this great rom...
    installed sailfish release 2
    Works great and the ui is smooth and awesome...will use it as my daily driver..changed the governor to conservative..still as smooth as it can be...
    @vgrade :: changing in-call volume has no effect...i mean it doesnt increase or decrease the volume...though the slider moves..
    *for those who are unable to activate mobile data even after setting apn settings...in the sttings->cellular network->manually set the network to other than your sim network..then it will show error....then select your network from the available networks..this will enable the option to enable mobile data...this worked for me..;)
    Edit : changing the network type from 3g to 2g..will also enable option to turn on mobile data..once enabled you can change back to ur preferred network type...
    Enjoying Sailfish on my OPO...
    msri3here and vgrade like this.
  8. sathish D C
  9. VeryMilan
    Well. I had big troube to find a good subdomain.
    Maybe a main domain would be more nice for something like that, but .tk adresses for example doesnt work on all countrys. sadly. Will see.
    For now the site is available under the following adress: http://sailfish-for-opo.tchncs.de/
    Maybe TLS will follow.
    Note: this page is still under construction an unfinish.
    Please give me feedback to improve this page.
    Regards.
    Edit: the main reason, that i published on this state is, that i am away the complete day tomorrow and i wanna bring some result after talking :)
    Edit2: well, smooth scrolling and backtotop seems only work propertly on Firefox, sorry, i checked chromium the first time now :(
    Edit3: successfully tested in midori, so its not an general webkit problem. good to know.
  10. vgrade
    vgrade , Jan 20, 2016 :
    Jolla stock apps can be installed (see instructions in thread) but full store (minus alien dalvik, maps, MS exchange and xt9) requires Jolla to update backend servers to allow openplus devices. Its in progress.
    vgrade
    BTW - You didn't answer my question about what apps you need?
  11. vgrade
    Thanks it looks great, this is really appreciated and helps me spend time on the port
    vgrade
  12. vgrade
  13. vgrade
    Thanks very much for the kind words and bug report on volume control.
    bugs like this can be reported at https://bugs.merproject.org/
    I can't promise to resolve asap but at least its logged and sometimes we have the same bug on multiple ports.
    BR
    vgrade
    Sudheer4188 likes this.
  14. zjxpot
    Gingerbread Jan 21, 2016
    Hex and vgrade like this.
  15. Logan_Adams
    Logan_Adams , Jan 21, 2016 :
    Well I absolutely need for example Whatsapp and Twitter.
  16. Thangarun15
    Cupcake Jan 21, 2016
  17. VeryMilan
    Honeycomb Jan 21, 2016
    VeryMilan , Jan 21, 2016 :
    "Note: as every Linux Distribution, you may find other codecs if needed for unfree mediatypes.
    Maybe you want to search after codec-package names for multimedia in the internet.
    The package names for fedora might be helpful!"
    I dont have Sailfish yet. Maybe gstreamer0.10-ffmpeg is helping, @Thangarun15
  18. vgrade
    vgrade , Jan 21, 2016 :
    TweetIan for twitter get from warehouse, not sure about whatsapp, there was a sailfish client at one time.
    vgrade
  19. jeffhoogland
    jeffhoogland , Jan 21, 2016 :
    Has anyone been able to get the Youtube and / or Twitch video applications to work? They both play audio for me, but the video itself is blank :-/
    Added codecs and FFMpeg packages are the first post suggests for video support.
    vgrade likes this.
  20. CBpbxEcmecmBeH
    Jelly Bean Jan 21, 2016
    CBpbxEcmecmBeH , Jan 21, 2016 :
    One more thing, IMHO, you should also look at the development in TMO forum, the best place for 3rd party developers working on SailfishOS
