2
Samsung gear Plugin battery drain
  1. Abhishek_chaphekar_5391
    Cupcake Dec 1, 2019
    Abhishek_chaphekar_5391 , Dec 1, 2019 :
    So recently I purchased Samsung galaxy Watch and installed all the necessary plugins... I am facing a battery drain issue with the plugin to as high as 18% through the plug-in... anyone facing the same issue?
    Aman10600 and opzesuser like this.
  2. nite_vizion
    Cupcake Dec 3, 2019
    nite_vizion , Dec 3, 2019 :
    Yes!
    I've uninstalled/reinstalled app, factory reset watch... galaxy watch plugin still draining my battery 2x faster than normal; using 11-17% battery even when restricted in background.
    It's frustrating af and I've found ZERO solutions after comprehensive searching.
    opzesuser likes this.
  3. opzesuser
    Cupcake Dec 3, 2019
    opzesuser , Dec 3, 2019 :
    I've the same issue with my battery drain persisting even when I change the power management setting to 'Optimize'. Remind me again why I hate Samsung.
  4. Abhishek_chaphekar_5391
    Cupcake Dec 3, 2019
    Abhishek_chaphekar_5391 , Dec 3, 2019 :
    Ok I have found the solution... just downgrade the version of gear Plugin... the update released on 19th November is having issues... Download the previous version which was launched in September... worked like a charm for me 😬
    let me know if it works for you too
    javieloski likes this.
  5. V1570291036907
    Cupcake Dec 15, 2019
    V1570291036907 , Dec 15, 2019 :
    How do you downgrade the version? I litteraly have no clue how to do that.
  6. opzesuser
    Cupcake Dec 23, 2019
    opzesuser , via OnePlus 6 , Dec 23, 2019 :
    Go to apkmirror.com and download September version. Do note your watch will have to be reset so take a backup first and then uninstall currently installed version.
  7. botwijns
    Cupcake Jan 8, 2020
    botwijns , Jan 8, 2020 :
    I have the same problem but my galaxy wearable app doesn't respond to my already installed watch active 2 plugin from an earlier version. don't know what to do now
  8. lolomjj
    Froyo Jan 10, 2020
    lolomjj , Jan 10, 2020 :
    OK I had the same problem on my 6T and I believe I've found a solution.
    You'll need to deactivate the battery optimization on all the Galaxy Wear apps & plugins as it force closes them and makes them reboot all the time, creating the battery draining.
    I've tried that for a couple of days now and it seems to have eradicated the phenomenon.
    Let me now if it worked for you too!
    T1572505891413 and gdaddikar like this.
  9. Aless4ndro
    Cupcake Jan 10, 2020
    Aless4ndro , Jan 10, 2020 :
    I have the same problem on my op6 with Android 10, both devices (watch and phone) are correctly updated but I noticed a battery drain from that plugin. I'll try what lolomjj suggests. I'll let you know in a few days.
  10. Aless4ndro
    Cupcake Jan 14, 2020
    Aless4ndro , Jan 14, 2020 :
    After 3 days I can say that the battery drain stopped, however I have another problem. Yesterday the plugin app auto update and now the phone does not more connect with the watch. I think I have to downgrade with the apk or wait for another update. This make me so frustrated.
  11. Buic
    Eclair Jan 15, 2020
    Buic , Jan 15, 2020 :
    Hi Alless4ndro, I have a problem with my Galaxy Watch, I can't connect to the store and can't download watch faces from the samsung app (7T Android 10) :S maybe downgrade the plugin or the samsung app ?
  12. gdaddikar
    Cupcake Jan 15, 2020
    gdaddikar , Jan 15, 2020 :
    Lolomjj is right to his words..i tried too and it worked..now Samsung gear eats only 2-3 % of total battery in 1 cycle
  13. Aless4ndro
    Cupcake Jan 17, 2020
    Aless4ndro , Jan 17, 2020 :
    Hi buic, I really don't know what to do, today my watch active 2 doesn't connect anymore with my smartphone. I tried all the possible solutions by me but I think I'll have to contact the Samsung support, it's unacceptable that a brand new smartwatch doesn't work with a OnePlus. I'll let you know if they tell me something good. Byee
  14. Buic
    Eclair Jan 17, 2020
    Buic , Jan 17, 2020 :
    Ahh okay :) I also spoke with samsung uk, and ofc they pointing fingers at oneplus :D
  15. Aless4ndro
    Cupcake Jan 18, 2020
    Aless4ndro , Jan 18, 2020 :
    I would have bet on it!
  16. Buic
    Eclair Jan 18, 2020
    Buic , Jan 18, 2020 :
    Only 1 thing I don't understand :D why they keep support if its utterly useless almost 99.9% of the time
  17. Aless4ndro
    Cupcake Jan 20, 2020
    Aless4ndro , Jan 20, 2020 :
    Hi guys, anther day another problem. Today Samsung decided randomly to drain my op6 battery with the "Samsung accessory service" and "Samsung health". I am seriously thinking to make a return of the watch. Too many problems with the applications. I would know If even Samsung (galaxy, note ecc.) have the same problems. In attached a screenshot of yesterday. Screenshot_20200120-133911.jpg Screenshot_20200119-211850.jpg
  18. Buic
    Eclair Jan 20, 2020
    Buic , via OnePlus 7T , Jan 20, 2020 :
    try to put all of the samsung apps into no battery optimalization, and see if it helps
  19. Schutzy54
    Cupcake Jan 21, 2020
    Schutzy54 , Jan 21, 2020 :
    Hi, I also have the same problem here. I have a OnePlus 7 Pro and a Samsung Watch Active 2. Before buying my watch, my phone's battery lasted 2 days. Since then I have to charge my phone every night. When I look in the battery settings, it is com.samsung.android.gearrplugin that consumes the most.
    While reading this post, I just turned off battery optimization for all samsung plugins. Let’s see ... I’m trying to keep you informed.
  20. Aless4ndro
    Aless4ndro , Jan 21, 2020 :
    I already did it, I solved by rebooting watch and phone. Thank you anyway 👍👍
    Buic likes this.
