Samsung Gear S2 Compatibility?
  1. Ted_Winter
    Donut Nov 19, 2015
    melamudv and ik1 like this.
  2. Timzai
    Cupcake Nov 19, 2015
    Timzai , Nov 19, 2015 :
    Looks like the same 3 apps I installed also :) these won't probably update themselves so it would be good to keep track of the newest apk's. Any thoughts on how that could be done easily?
    Jorge48197 likes this.
  3. eu.Andrei
    Cupcake Nov 27, 2015
    eu.Andrei , Nov 27, 2015 :
    GEAR S2 WORKS WITH ONEPLUS X
    I would like to confirm that Gear S2 absolutely does work with OnePlus X. It is not direct however and you have to install plugins/gear manager apps as instructed in posts found in this thread, but after doing so, you will find that it all works perfectly well as expected. Sorry for the headache you're may have experienced, but don't give up, just read and do.
    I am experiencing no errors at all.
    The only thing you will not get while using a Gear S2 with a none Samsung phone is paid apps. You will be able to install all the free apps for your Gear S2, but not paid ones yet.
    ik1 likes this.
  4. lamoucheuk
    Cupcake Dec 7, 2015
  5. Encryption
    Cupcake Jan 7, 2016
    Encryption , Jan 7, 2016 :
    Hey just wanted to revive this thread a bit for a couple specific questions regarding the OPO and the Gear S2 compatibility. For those that have their OPO and Gear S2:
    1. Is it still working?
    2. Have you updated the samsung app at all lately?
    3. Are there any functions or features that do not work? (Calls, messages, app crashing)
    4. Are you rooted?
    5. What ROM are you using? (EX: I'm currently on CM12.1)
    Thanks much!
    Mr75 and Jorge48197 like this.
  6. Jorge48197
    Gingerbread Jan 10, 2016
    Jorge48197 , Jan 10, 2016 :
    Can you write down the steps for me?
  7. Mr75
    Cupcake Jan 14, 2016
    Mr75 , Jan 14, 2016 :
    I'm asking the same question i want to buy this days And i want to be sure before :/
  8. dchristenhusz
    Cupcake Jan 24, 2016
    dchristenhusz , Jan 24, 2016 :
    I decided to buy a Gear S2 although I didn't know if it would work. I can tell you it works like a charm with my OPO. I had absolutely no problem with the connection. To answer the above questions:
    - it still works, no problem at all
    - I downloaded the samsung app from the playstore yesterday.
    - I got my watch yesterday so I can't tell you that much about it. I recieve my mail and whatsapp without any problems. This morning I ran with nike+ without any problems.
    - I use my OPO out of the box, so no tweaks
    - my CM version is: 12.1.1-yog7das2k1
    I hope this answers your questions
  9. best86
    Cupcake Feb 11, 2016
    best86 , Feb 11, 2016 :
    I have the OPO and the smart watch and it is totally compatible ;)
  10. melamudv
  11. giridhar
    Gingerbread Mar 1, 2016
  12. satnamkhanuja
    Cupcake Apr 1, 2016
    satnamkhanuja , Apr 1, 2016 :
    any update??
  13. sameerbatavia
    Donut Apr 18, 2016
  14. Ineedthisphone2bad
    Cupcake Jun 17, 2016
    Ineedthisphone2bad , Jun 17, 2016 :
    Ok guys...ITS ABOUT TIME...can anyone confirm if the gear s2 works with OP3 as yet...I already have a gear S2 and I ordered my OP3...excited for its arrival and could really use some reassurance that my gear S2 will still work
    BrechtDD likes this.
  15. BrechtDD
    Cupcake Jun 22, 2016
    BrechtDD , Jun 22, 2016 :
    I just ordered the OP3 and would like to buy the Samsung Gear S2 (classic). Do you already know something more about the compatibility?
  16. maxstnr
    Cupcake Jun 24, 2016
    maxstnr , Jun 24, 2016 :
    I got my S2 to work, but only after I performed a factory reset on it. The OP3 refused to connect to it until I did that.
  17. Ineedthisphone2bad
    Cupcake Jun 26, 2016
    Ineedthisphone2bad , Jun 26, 2016 :
    OK guys...update time, I literally jus finished restoring my gS2 configuration after successful sync with my OP3....everything runs as expected so far....so I guess it works...#goodjobONEPLUS
  18. StewieGriffin
    Cupcake Jul 19, 2016
    StewieGriffin , Jul 19, 2016 :
    Hi there, anyone connected a Samsung Gear R380 successfully? Thx, Stewie
    #38
  19. Jack9898
    Cupcake Aug 28, 2016
    #39
  20. Eisregen1349
    Cupcake Dec 23, 2016
    Eisregen1349 , Dec 23, 2016 :
    I've bought the Gear S2 classic and tried to configure it with my OP3. First Day, no notifications are shown on the watch. After hours of researching on google I restarted my OP3, and then the notifications came through.
    But that glorious moment lasts only 1 Day!!!
    On Day 3, no Notifications came through and even reinstalling the Samsung Gear App and the plugins and even resetting my watch made no difference.
    Someone else here who can report this issues or maybe has a solution for this?
    Btw, sorry for my bad english, I'm from Germany ;)
    #40
