Schedule power on and off`
  1. nrkpai
    Eclair Dec 18, 2014
    nrkpai , Dec 18, 2014 :
    Is there any app that I can use to schedule the power off and on at a certain time automatically or any mod that can be flashed to OPO to activate this option.
    Regards,
  2. GeertBerkers
    Lollipop Dec 18, 2014
  3. simonc76
    Jelly Bean Dec 18, 2014
    simonc76 , Dec 18, 2014 :
    Why would you want to do that????
  4. Spper
    Eclair Dec 18, 2014
    Spper , Dec 18, 2014 :
    Why not? There's some apps to allow your device to go hibernate for a fast boot like window 8 does.
  5. JamalOP
    Gingerbread Dec 18, 2014
  6. GeertBerkers
    GeertBerkers , Dec 18, 2014 :
    Then the OP had to ask another question.
    But when also when hibernated, you need to boot manually.
    Not with a program, else it still isn't hibernated.
    Spper likes this.
  7. eranm5
    eranm5 , Dec 18, 2014 :
    The clock app turns the OPO on 2 minutes before alarm time if it's activated.
    WakaWakaWaka and clayginn like this.
  8. gusuraman
    Global Head Moderator Dec 18, 2014
    gusuraman , Dec 18, 2014 :
    Setting the built-in alarm will power on the phone;)
    superplus, GeertBerkers and ramsabi like this.
  9. ramsabi
    ramsabi , Dec 18, 2014 :
    The alarm does it. So it must be possible.
  10. GeertBerkers
    Didn't knew that :eek:
    gusuraman likes this.
  11. dcoulombe
    Ice Cream Sandwich Dec 18, 2014
    dcoulombe , Dec 18, 2014 :
    Use AutomateIt Pro to shutdown the device and the stock CM11S alarm (with a silent alarm) to power on the device.
    Profits !
    nrkpai likes this.
  12. gusuraman
    The phone will turn on 2 or 3 minutes before the alarm set time. With QuickBoot enabled at the set time.
    It works only with the default alarm app
  13. nrkpai
    Eclair Dec 19, 2014
    nrkpai , Dec 19, 2014 :
    say at 10.30 pm I would like to switch off the phone and at 6.00 am, it would wake up automatically.. This way you can save battery.
    avinashorai likes this.
  14. nrkpai
    Eclair Dec 19, 2014
    This option is there in other phones that I used earlier.
  15. simonc76
    Jelly Bean Dec 19, 2014
    simonc76 , Dec 19, 2014 :
    Your phone will only use 1-2% overnight and most people charge their phones overnight anyway.
  16. nrkpai
    Eclair Dec 20, 2014
    nrkpai , Dec 20, 2014 :
    That's great piece of information. Can you please shed more information on how to set up this option in alarm setting.
    Thanks in advance
  17. eranm5
    Jelly Bean Dec 20, 2014
    eranm5 , Dec 20, 2014 :
    Just set an alarm and turn your device off, there's nothing to change in the settings. Good luck :)
  18. nrkpai
    Eclair Dec 20, 2014
    Thanks for the information. It really works. I wasted lot of time in search of app. You are my hero.
    eranm5 likes this.
  19. ahighfield
    KitKat Dec 20, 2014
    ahighfield , Dec 20, 2014 :
    That's a good solution (with a short and silent alarm ring?), but lot's of phones have what the OP was asking and I asked myself the same question when I got my OPO too, eg my blackberry has had this for years, and I just set it everyday between 1am and 6am. My last Android phone, an Alcatel, also had this built into their OS. It's not unusual at all..
    Tricia24 likes this.
  20. bombadier
    KitKat Dec 20, 2014
    bombadier , Dec 20, 2014 :
    good tip about the alarm being able to turn the device on, At least don't think any of my previous phones would turn on if an alarm was set definitely not my nexus 4
    Everyday a school day
