2
Scratches on OnePlus 8 via OnePlus 8
  1. Neoharys.
    Froyo Oct 5, 2020
    Neoharys. , via OnePlus 8 , Oct 5, 2020 :
    I bought my OnePlus 8 four months ago, today I removed it's pre-applied screen protector and noticed there's a scratch on the screen. I feel like I've been cheated by OnePlus, my device is still under warranty but the return window is closed. Except for the scratch the phone works without any issues, I'm going to use this phone atleast for 4 years and the scratch is literally on the centre. What can I do now? please help me
    Neoharys and SyedYaseenOP8 like this.
  2. jd2016
    Gingerbread Oct 5, 2020
    krsam likes this.
  3. Neoharys.
    Froyo Oct 5, 2020
    How is it my fault? the scratch was below pre applied protector, i removed it today and it was already there
    I1572052715870 likes this.
  4. Atul Menon
    Honeycomb Oct 5, 2020
    jd2016 likes this.
  5. Neoharys.
    Froyo Oct 5, 2020
    It's my mistake for trusting a premium company that there won't be a scratch beneath the screen protector after 4 months?
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 5, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 5, 2020 :
    You could try a warranty replacement. The problem is however to prove that you didn't cause the scratch yourself
    DrJMun likes this.
  7. Neoharys.
    Froyo Oct 5, 2020
    Any suggestions how can I prove it? I know it's late now, but I literally had no idea the scratch was on the screen and not on the protector. This is the only helpful comment I got so far, thanks
  8. Swejuggalo
    Well... A tricky situation. Maybe they can prove it via a microscope inspection comparing flawless areas and the scratch and do a qualified guess on your claims. But it can very well be a word against word issue.
  9. Neoharys.
    Froyo Oct 5, 2020
    So should I take it to the service center and see what happens?
  10. Swejuggalo
    Akshatt Seth likes this.
  11. #11
  12. Neoharys.
    Froyo Oct 12, 2020
    Neoharys. , via OnePlus 8 , Oct 12, 2020 :
    That's what I thought, I've seen jerry rig and all the drop tests
  13. HrudayH111
    Donut Oct 27, 2020
    HrudayH111 , via OnePlus 8 , Oct 27, 2020 :
    Even I have got pretty deep scratch in mid of my Op8 Display, I have tried Tempered glass with "UV Glue" as the glue get into the crease of deep scratches it filled in soo well and ever since i couldn't even find a single scratch at all (unless u remove the protective UV glass). Trust me Glazedinc UV glass for Op8 is the best.
    SyedYaseenOP8 likes this.
  14. TibiTibi
    Photography Expert Community Expert Oct 27, 2020
    TibiTibi , Oct 27, 2020 :
    It cannot be solved in the forum.
    You should ignore it or try a magical screen repair fluid
  15. KubaLibre
    Eclair Oct 28, 2020
    KubaLibre , via OnePlus 8T , Oct 28, 2020 :
    Hallo
    Install new Nano Tpu film or liquid Nano.
    It's self repair and you don't see the scratches on your screen.
    Try eBuy, schutsfolien24, Amazon.
    Haved same by my first device, don't worry.
    Regards
    KL
  16. AstroBoy786
    Cupcake Nov 1, 2020
  17. Shazzad27
    Cupcake Nov 2, 2020
    KubaLibre likes this.
  18. Snehu_IN
    Gingerbread Nov 3, 2020
    Snehu_IN , via OnePlus 8 Pro , Nov 3, 2020 :
    So you say you saw the scratch earlier and thought it was on the screen protector right? So from when did you see this scratch? Immediately after purchase or later? If it was later then it means there was some physical damage which means it is not a scratch but a hairline crack which should have happened from a fall it a hard hit or something.
  19. #19
  20. SweetArwa
    Froyo Nov 3, 2020
