4
screen brightness fingerprint scanner
  1. hiddeeeeeee
    Donut Nov 29, 2018
    hiddeeeeeee , Nov 29, 2018 :
    I understand that for the scanner to work you need to put it in full brightness. But since it's AMOLED I wondered if the clock part of the screen could stay dimmed. I think this would make the user experience of the scanner at night much better.
    Thanks for listening
  2. CrazyGamer1333
    Cupcake Nov 29, 2018
    CrazyGamer1333 , Nov 29, 2018 :
    What phone do you have?
  3. hiddeeeeeee
    Donut Nov 29, 2018
  4. stbn84
    Gingerbread Nov 29, 2018
    stbn84 , Nov 29, 2018 :
    CrazyGamer1333
    What phone do you have?​
    ‍The only OnePlus device with an in-display scanner...
    Sargo likes this.
  5. CrazyGamer1333
    you shouldn't need to put the bright to full to use the fingerprint scanner an bright will do.
  6. Logancd1
    Ice Cream Sandwich Nov 29, 2018
    Logancd1 , Nov 29, 2018 :
    Actually because the optical scanner requires light to capture an image of your fingerprint, full brightness is required. However, you don't have to manually do that. Once you place your finger over the sensor, the phone automatically lights up at full brightness to identify the fingerprint. I could've sworn it was only at the location of the fingerprint sensor, though, not the whole screen. Let me test it out really quick.
    EDIT: I guess it does light up the whole screen. Huh. Interesting.
    inavda and Mavalos415 like this.
  7. Neddard
    Lollipop Nov 29, 2018
    Neddard , Nov 29, 2018 :
    You should have a look at the (too) many threads on this subject.
    The optical FPR tech requires the extra brightness for reading accuracy. Some people are hoping that the process can be changed to only light the FPR touch area to full brightness rather than the entire screen.
  8. Lucky M. Nelson
    Froyo Nov 29, 2018
    Lucky M. Nelson , Nov 29, 2018 :
    Mine goes full bright only at the location of the scanner. The rest of the display stays the same brightness.
  9. Logancd1
    Might just be from locked then. I was just testing out from the ambient display mode to unlocked using the fingerprint sensor, and the clock lights up as well there.
  10. Neddard
    Try it with ambient display activated in Settings. I believe that you'll see the entire screen brighten. If you press the Power button first, then I don't think the whole screen brightens.
  11. Lucky M. Nelson
    Froyo Nov 29, 2018
    Agreed.
  12. Lucky M. Nelson
    Froyo Nov 29, 2018
    Yah, the rest of the display goes full brightness when in ambient display mode.
  13. Neddard
    Ambient display mode light-up is what's upsetting some folks. They want/use the ambient display feature, but complain about the light-up. Some of the threads are... amusing. ;)
    NMD2018 likes this.
  14. Lucky M. Nelson
    Froyo Nov 29, 2018
    I kinda disabled it for that reason... mainly because with my device, I noticed that it took just a second longer for the fingerprint to scan my finger, whereas with the lockscreen, it's a tad faster at unlocking my device.
  15. Neddard
    Right, but that bit of 'tad faster' gets used up having to push the power button to bring up the lock screen, no? ;)
    I like the 'pick up to show' feature of ambient display. then the FPR is right there ready to read. And, I'm not a bit bothered by the whole screen lighting up for the instant it takes to unlock. If OP decides to modify it to only the FPR area, cool. But if not, fine by me, too. :D
    Lucky M. Nelson likes this.
  16. TalangaraSuhail
    Donut Nov 29, 2018
    TalangaraSuhail , Nov 29, 2018 :
    you must have the face unlock on.
    in low light areas the face unlock flashes the screen in order to pick bio up and subsequently open the phone.
    I find it too conflicting with fingerprint anyways so i turn it off.
    also it takes up additional battery as it runs Everytime you try to unlock regardless of fingerprint attempts or not .
  17. J_Parth_Patel_120595
    Gingerbread Nov 30, 2018
