2
Screen brightness slow to get bright when unlocking phone via OnePlus 9 Pro
  1. yajimbo
    Eclair Jul 20, 2021
    yajimbo , via OnePlus 9 Pro , Jul 20, 2021 :
    Recently I have noticed that when I unlock my phone and the screens has beens off it takes a second or two for it to get to full brightness.
    I've checked all the settings and can't see anything that would cause it.
    Has anyone else experienced this?
    lweisenbacher and P1617751667994 like this.
  2. Ninxha
    Honeycomb Jul 20, 2021
    yajimbo likes this.
  3. Jayosen671
    Eclair Jul 20, 2021
    RazvanScutea and P1617751667994 like this.
  4. Flashfox_Prime
    Cupcake Jul 21, 2021
    P1617751667994 likes this.
  5. the_o2
    OnePlus 9 Series Expert Community Expert Jul 21, 2021
    the_o2 , Jul 21, 2021 :
    Is it still happening after latest 11.2.8.8 update?
    RazvanScutea and raidden like this.
  6. yajimbo
    Eclair Jul 21, 2021
  7. yajimbo
    Eclair Jul 21, 2021
    yajimbo , via OnePlus 9 Pro , Jul 21, 2021 :
    I've not received that update yet, my phone is at 11.2.7.7 hopefully when I get that it could resolve it 🤞🏽
    the_o2 likes this.
  8. Ninxha
    Honeycomb Jul 21, 2021
    Ninxha , Jul 21, 2021 :
    Is your comfort tone also off? Maybe that gives the effect if its on.
  9. yajimbo
    Eclair Jul 21, 2021
    That is off as well, I'll just have to wait and see if the next update clears it
    P1617751667994 and Ninxha like this.
  10. raidden
    Cupcake Jul 22, 2021
    raidden , Jul 22, 2021 :
    I bought OnePlus 9 pro a week after it came out and had the same issue since day 1. Is so annoying. Phone still have a lot of issues not solved. Like overheating. Was watch youtube for 1h and then it's show your phone is overheating. Battery draining faster than usual. And so on. Very despondent in 1+9pro.
  11. Nakata24
    Froyo Jul 22, 2021
    Nakata24 , via OnePlus 9 Pro , Jul 22, 2021 :
    It still happen with the newest 1.2.8.8 software, also notice the power button is not direct unlock the phone like my op 7pro does, sometimes i need to press a couple times to wake the phone up. How come this phone got so many problems, even the nord response faster than this phone.
  12. Flashfox_Prime
    Cupcake Jul 30, 2021
  13. Harsha_Vardhan_ , via OnePlus 9 Pro Pine Green , Jul 30, 2021 :
    The proximity sensor taking a second time to check the lighting arround you, this is happening all devices but in other varient a white screen will pop up instead of increasing brightness maybe because is this you may not notice in other devices but oneplus 9 pro u can observe that because of smooth display, this is not the defect. This is just a normal feature
  14. Nakata24
    Froyo Jul 31, 2021
    CS1989 and P1617751667994 like this.
  15. #15
  16. Nakata24
    Froyo Aug 1, 2021
    Nakata24 , via OnePlus 9 Pro , Aug 1, 2021 :
    My 7 pro didnt had this issue, its a 9 pro issue for sure and not a feature. Can u plz make a screenshot of this feature?
  17. G1543551283381
    Cupcake Aug 1, 2021
    G1543551283381 , Aug 1, 2021 :
    Happened to me two times today in a span of 10mins. I've sent in the logs today to see if they can find what the issue is.
    I had the 7t Mclaren edition and the 6t and this was never an issue before.
    CS1989, P1617751667994 and Nakata24 like this.
  18. djo.dadof2
    Cupcake Aug 13, 2021
  19. R1628950288784
    Cupcake Aug 14, 2021
  20. P1617751667994
    P1617751667994 , Aug 14, 2021 :
    Definitely a lot of bugs with 9 pro. Really disappointed because I was so happy with the 7 pro that I bought the 9 pro the day it came out. Have numerous issues to the point I will not buy another one plus phone after this. Proximity sensor is trash. Doesn't recognize when my face is near the phone to keep it from pressing random buttons. Doesn't recognize when there is nothing near the sensor which triggers pocket mode so I can't answer phone quickly. And even with auto dimming and comfort vision turned off it will suddenly dim while I'm watching videos. Browsing the forums these same issues have been reported numerous times for months with no real root cause resolution. So it's time to get the message across by using my pocket book and taking my hard earned dollars elsewhere.
    yajimbo likes this.
