Screen calibration, night mode and read mode not working
  1. ScicoPax
    Cupcake Apr 10, 2021
    ScicoPax , Apr 10, 2021 :
    I just noticed one day that these three functions are locked and can't seem to enable them. How may I fix this without wiping my phone?
  2. B_Wrath
    Nougat Apr 11, 2021
    Best Answer
    B_Wrath , Apr 11, 2021 :
    That's nuclear option.
    Go to settings >system >accessibility. In that, turn off "color correction" under display.
    the_o2, ScicoPax and Caoimhín like this.
  3. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 11, 2021
    Caoimhín , via OnePlus 6T , Apr 11, 2021 :
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    ⚠️This will not delete your apps data but you will have to provide permissions for all your Apps again.⚠️
    Check if this can help.
  4. Caoimhín
    Thought maybe it was a permissions issue. Came across it before where an app that was similar to a system feature overwrote the permission of that feature and became the default app. Sometimes it can be hard to trace which 3rd party app may have done that. Just my train of thought.
    Anyway, also possible an accessibility issue too.
  5. ScicoPax
    Cupcake Apr 11, 2021
    ScicoPax , Apr 11, 2021 :
    I don't have enough words to express my gratitude, thanks a lot!
    the_o2, Caoimhín and B_Wrath like this.
  6. B_Wrath
    Nougat Apr 11, 2021
    It is usually caused by apps which have a control over your display settings. For example, blue light filter apps, apps which try to emulate greyscale feature of digital wellbeing, etc.
    Caoimhín likes this.
  7. B_Wrath
    Nougat Apr 11, 2021
    Happy to help:)
  8. Caoimhín
    B_Wrath likes this.
