Screen cast / Wi-Fi connection Hotspot issues. .. via OnePlus 6T
  1. H1557058226130
    Gingerbread Oct 20, 2020
    H1557058226130 , via OnePlus 6T , Oct 20, 2020 :
    Screen cast connection errors , while connecting several times failed to pair..
    Too bugy ...
    Wi-Fi connection & Hotspot failed sometimes to connect & data sharing errors occurred
  2. Caomhin
    Marshmallow Oct 21, 2020
    Caomhin , via OnePlus 6T , Oct 21, 2020 :
    Make sure you are on the same network as your TV.
    Open the Cast app, click the 3 dot menu top right and make sure Enable Wireless Display is ticked.
    Also reset your WiFi adapter on the phone.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    See if that helps.
    H1557058226130 likes this.
  3. H1557058226130
    Gingerbread Oct 22, 2020
    H1557058226130 , via OnePlus 6T , Oct 22, 2020 :
    Thank you..
    Caomhin likes this.
