screen edge touch issue via OnePlus 9
  1. SalLmc
    Donut May 6, 2021
    SalLmc , via OnePlus 9 , May 6, 2021 :
    the edge of the screen has a low sensitivity. especially when I touch the edges with 2 fingers at the same time. it seems like a feature preventing carelessly touch on the curved edge device like op9pro. however op9 has a flat screen, which makes this problem quite annoying.
    I think quite a lot users have the same problem, but it's unsolved so far.
    Racer11 likes this.
  2. Liehjan
    Marshmallow May 6, 2021
    Liehjan , May 6, 2021 :
    You should report it here too, so that bughunters can be in touch with you.
  3. SalLmc
    Donut May 6, 2021
    Bobbie63 and Liehjan like this.
  4. Sheppards
    Jelly Bean May 6, 2021
    Sheppards , via OnePlus 7T , May 6, 2021 :
    I think this most likely is due to the back gesture. At least I think.
    Try changing to back, home and recent virtual buttons and see if it makes a difference (and if you're not already using them)
    Tokolozi and Bobbie63 like this.
  5. SalLmc
    Donut May 6, 2021
    Have tried it, still won't work. Probably because they forget to turn off the feature which prevents accidentally touch on edge on curved edge devices like op9pro. So when using a flat screen device like op9 , it's quite annoying
    Bobbie63 likes this.
  6. khelannn
    Froyo May 10, 2021
    khelannn , via OnePlus 9 Pro , May 10, 2021 :
    yep i would post it anywhere i like or wish.....what do you expect from a unsatisfied consumer ?
    if your phone had such issues every week u would get me brother
