screen heating issue
  1. get_never_settle
    Froyo Feb 8, 2015
    get_never_settle , Feb 8, 2015 :
    My OPO Screen gets hot from the upper portion, sometimes when i am using it and sometimes when its on charging. The screen really gets hot and i can smell it like some component is burning inside...dont know what's the reason and what to do. i just switch off my phone for some time so that it does nt get damage.
    Anybody else facing this issue??
    Hiback likes this.
  2. Faraz. Dipsite
    Honeycomb Feb 8, 2015
  3. imTSS
    KitKat Feb 8, 2015
    imTSS , Feb 8, 2015 :
    Ya post screenshot of the temp of CPU as well as battery
  4. get_never_settle
    Froyo Feb 10, 2015
    get_never_settle , Feb 10, 2015 :
    Will post when i'll face the same issue next time. :(
    Actually i really dont want this to happen again. fingers crossed
  5. butaixyz8016
    Honeycomb Feb 10, 2015
    butaixyz8016 , Feb 10, 2015 :
    when did u buy ur phone??
  6. sandeep_khopade
    Ice Cream Sandwich Feb 11, 2015
    sandeep_khopade , Feb 11, 2015 :
    Hope you are using the charger provided by OP. Don't use any other charger.
  7. get_never_settle
    Froyo Feb 13, 2015
  8. get_never_settle
    Froyo Feb 13, 2015
    get_never_settle , Feb 13, 2015 :
    I am using the original charger. I don't face this issue regularly. It happened 4 or 5 times in the past 2 months
    harsha41 likes this.
  9. harsha41
    Eclair Feb 13, 2015
    harsha41 , Feb 13, 2015 :
    Service center no other option left
  10. Nigarkhayam
    Cupcake Mar 15, 2015
    Nigarkhayam , Mar 15, 2015 :
    I got my ops one week back. Every time I do video chatting it gets heated. Even if I chat for 5 mins, phone gets heated badly. Should I return the phone or is this normal?
  11. angadV
    Honeycomb Mar 15, 2015
    angadV , Mar 15, 2015 :
    Yeah dude, one week means you can return via Amazon instead of service centre (10 day period offered by amazon). Do so immediately, you'll save yourself a lot of hassle :)
  12. angadV
    Are you sure you smell something burning? o_O
    Download the CPU temp app, and enable overlay, shows your temperature on status bar. If <65° its perfectly fine. It would only exceed that after heaby long period usage.
  13. Nicky_Sharma
    Nicky_Sharma , Mar 15, 2015 :
    This is normal bro
  14. Sharmil
    Cupcake Mar 19, 2015
  15. parthi5591
    Cupcake Mar 29, 2015
    parthi5591 , Mar 29, 2015 :
    Ideally my phone temperature is 40 c when playing games for even 15 mins it hikes to 52 is it normal .Gamez I used to play are surf way surfers and candy crush saga
  16. elajohri
    Cupcake Aug 19, 2015
    elajohri , Aug 19, 2015 :
    Same issue here. Although I do not use any apps except FB and emails and strictly not even a single game. Through the Temperature App I ascertained that it goes to over 52 Degree Celcius when talking on the phone (That's why we really buy the phone, right :) ). I can feel the difference in temperature in upper and lower bottom of the phone. Done factory resetting, firmware updated and reinstated. Still the same. I have raised a case. Keeping fingers crossed.
  17. rudra mitra
    Eclair Aug 20, 2015
    rudra mitra , Aug 20, 2015 :
    Its not worth waiting for OPS, go for MX5 Meizu.. that is far better, launching next week in india
    , no invite
  18. ravi4ever
    Community Veteran Aug 20, 2015
    vaibhav_diamond likes this.
  19. Shravanshetty11
    Gingerbread Aug 22, 2015
    Shravanshetty11 , Aug 22, 2015 :
    Does meizu have good service ?? I dont knw wher thy have a service center in south
  20. SoumayK
    Gingerbread Aug 24, 2015
