2
screen lock and app lock why same
  1. N1517157490471
    Cupcake Jul 20, 2021
    N1517157490471 , Jul 20, 2021 :
    why not different different password for screen lock and app lock in one plus 6 . there are same password for screen lock and app lock . other brands have options for different different password for screen lock and app lock
  2. N1517157490471
  3. N1517157490471
    why not different different password for screen lock and app lock in one plus 6 . there are same password for screen lock and app lock . other brands have options for different different password for screen lock and app lock please give the solution OnePlus india
  4. pablofg1978
    Head Moderator Head Moderator Jul 20, 2021
    pablofg1978 , Jul 20, 2021 :
    Hello there,
    If you don't share your screen lock with anyone there is no need for a different password.
    You can use the feedback section on the community app to submit your request directly to OnePlus
    Tokolozi and drl431 like this.
  5. N1517157490471
    but i will share my screen password in my family also but i don't want to share my app password to anyone else
  6. pablofg1978
    You should not share your screen password with anyone.
    That is why you have the option to use a guest profile.
  7. rhyd1am
    KitKat Jul 20, 2021
    rhyd1am , Jul 20, 2021 :
    There is no solution to give you. You can submit suggestions to Oneplus via the feedback option in the community app, it by using the link below
    https://forums.oneplus.com/feedback
    Personally I've never found a problem with the way things are in OOS. If I want to keep things in my phone private, I simply keep my pin for unlocking my device private 🤷🏼‍♂️
    Tokolozi, drl431 and McJader like this.
  8. rhyd1am
    KitKat Jul 20, 2021
    Don't you trust your family then?
    I've never had the need to hide anything, apps or otherwise from my wife 🤷🏼‍♂️
    Tokolozi, drl431, Dresa91 and 2 others like this.
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 20, 2021
  10. N1517157490471
    sir i have one more problem my screen off gasture not working after changing the display please give me solutions
  11. pablofg1978
    Thread merged
  12. SathiyaRock , via OnePlus 6 Mirror Black , Jul 25, 2021 :
    No solution till now for AppLock in OnePlus
  13. rhyd1am
    KitKat Jul 25, 2021
    rhyd1am , Jul 25, 2021 :
    The best solution is as mentioned below 🤷🏼‍♂️
    McJader and Tokolozi like this.
