2
Screen Lock Infinite Loop on OnePlus 7 Pro
Have you faced Screen Lock Loop?
  1. Yes
  2. No
Results are only viewable after voting.
  1. srikanthvnv
    Cupcake Nov 20, 2019
    srikanthvnv , Nov 20, 2019 :
    I am not able to unlock my OnePlus 7 Pro even after entering the correct PIN. I know its correct and also, if I enter a wrong PIN, the phone is clearly saying that it's a wrong PIN.
    After I enter the correct PIN, the phone flashes and is again getting locked. If I try to open settings by clicking the icon from Notification Pane, phone asks for a PIN. I enter it correctly, phone unlocks and shows settings page, but immediately gets locked again.
    Ideas tried:
    - Restarted many times. No use.
    - Went to Recovery Mode (Power + Volume Down). Then it asked for a Pattern whereas I use a PIN as my lock. Anyways, I gave the 2 patterns I had ever used on this phone. Surprisingly, none of them are working. No use.
    - Rebooted to safe mode. No use.
    Now the only way left for me is to clear everything by clicking "Forgot Password" in recovery mode.
    Background:
    Yesterday, my friend tried to change the wallpaper and did it a a couple of times. After few changes, the wallpaper panel didn't show any wallpapers at all and we were not able to change the wallpaper. We thought a restart should fix that issue.
    Today I have restarted my phone and now, the phone has gone into a screen lock loop forever. I don't want to go to a service center and make them delete all my data. Is there any other way for me to unlock my phone without losing any data?
    P1575728820457 and suchu_6 like this.
  2. suchu_6
    Cupcake Nov 23, 2019
    suchu_6 , Nov 23, 2019 :
    Am also facing the same issue exactly for last 2 days. Have also tried all reset except for the forgot password whuch will then erase all my data. Is there anyway to resolve this? If you get to know pls tell me as well. Thanks.
    P1575728820457 likes this.
  3. Z1575221316315
    Cupcake Dec 1, 2019
  4. G_Priyavrat_Sharma_IcWA
    Cupcake Dec 2, 2019
  5. getralaclema
    Cupcake Dec 7, 2019
  6. P1575728820457
    Cupcake Dec 7, 2019
    P1575728820457 , Dec 7, 2019 :
    I'm facing the issue too... Happened this morning and haven't found a solution since, hoping to get one soon though.
    @OnePlus please solve this issue ASAP and get back to this thread.
  7. Samytaha
    Cupcake Dec 8, 2019
    Samytaha , Dec 8, 2019 :
    Same issue here. Issue happened today after restarting my phone. Tried everything possible, restart, soft reset, removed the sim card, connected to the PC...etc. without success. The only left solution is a hard reset but I cannot afford to loose all my data and familiy pictures... I cannot perform any backup neither from the phone (locked in loop) nor from a computer as the USB debugging is not activated in my phone settings... @OnePlus PLEASE HELP AND ANSWER THIS THREAD...
  8. spot01
    Ice Cream Sandwich Dec 8, 2019
    G_plusone likes this.
  9. Samytaha
    Cupcake Dec 9, 2019
    Samytaha , Dec 9, 2019 :
    Thanks spot01. Managed to get in my settings menu using this UI bug technique but I still cannot perform any action that requires the PIN (and that includes system upgrade, USB debugging for backup from PC...etc.). I found someone that spotted the bug in the android code and sent to google support (see here) but no fix from them so far.
    I am now looking for a PC software that could force the USB debugg mode but I haven't found it yet.
  10. N1579451215955
    Cupcake Jan 19, 2020
    N1579451215955 , Jan 19, 2020 :
    I Have the same problem.
    My phone is getting locked surprisingly without any logic.
    After it occurs, I can't open it by fingerprint nor by face camera - only by PIN code.
    but even after using the PIN - it getting locked again and again.
    what is going on here ?!?!?!!?
    My phone is ONE PLUS 7 PRO - updated to last version.
    I have this issue for a month.
