6
Screen mirroring issue on Sony Bravia
  1. F_Mrunal_Dongare_eAie
    Eclair Dec 1, 2019
    F_Mrunal_Dongare_eAie , Dec 1, 2019 :
    My OP 7T is not connecting to my Sony Bravia smart tv through Screen mirroring..while my other phone i.e. OP 6T is connecting very well & work also very well...Plz..resolve this issue as early as possible.
  2. N1572605945261
    Eclair Dec 1, 2019
  3. S1577941663735
    Cupcake Jan 28, 2020
  4. karthik oneplus
    Ice Cream Sandwich Jan 29, 2020
    karthik oneplus , via OnePlus 7T , Jan 29, 2020 :
    I upgraded from oneplus 3T to 7T and was able to screen mirror without any problems using 3T.
    My 7T is displaying black screen with only some status info.
    Using Sony Bravia 4k TV. Fix this in next update.
    S1575430891497 likes this.
  5. S1575805794114
    Cupcake Feb 22, 2020
  6. AnuragKatkar
  7. L1548343178689
    Cupcake Mar 22, 2020
    L1548343178689 , via OnePlus 6T , Mar 22, 2020 :
    you can on WiFi option in Mobile and dawonload castto app in Mobile then you can select tv from app and connect it
    you don't need to WiFi connection just on it
    A1592072164450 likes this.
  8. kchinmay1697
    Cupcake Jun 9, 2020
    kchinmay1697 , via OnePlus 8 , Jun 9, 2020 :
    I just bought a One plus 8 and I have the same issue. The cast function gets connected to the TV but after that my tv screen turns completely black(blank).
  9. pranabss
    Gingerbread Jun 10, 2020
    pranabss , via OnePlus 7T , Jun 10, 2020 :
    Apps like Netflix, Prime video, Hotstar won't stream their content via screen mirroring. Thats not a bug. You can only cast via supported apps.
  10. T1518508796690
    Cupcake Jun 27, 2020
    T1518508796690 , Jun 27, 2020 :
    I have same issue with my samsung smart tv with my OP 7T. But When I try other mobile, it's work smoothly.
    Please do something immediately otherwise I want change mobile handset.
  11. harishke
    Gingerbread Jun 27, 2020
    harishke , via OnePlus 7T , Jun 27, 2020 :
    Try to enable force desktop in developer option and check ..i had this issue comnecting to external display by hdmi..after enabling it worked for me ..give it a try
  12. T1518508796690
    can't find developer option in op 7t.
    please guide me with step by step.
  13. harishke
    Click on about phone---> multi click on build.. Developer option gets enable and you will find it in system. At the bottom of developer option you will find force desktop
  14. T1518508796690
    sorry my friend,
    I follow all steps witch you suggest,but nothing to happen.
    TV show one plus 7 T is connecting..
    one plus 7 t connected....
    tv screen is black and right corner of tv showing loading...
    tv screen is completely black
    After five seconds, bottom of tv screen shows"screen mirroring has ended"
  15. harishke
    By what are you trying to mirror? Wifi out or hdmi ?
  16. T1518508796690
  17. harishke
    Gingerbread Jun 28, 2020
  18. T1518508796690
    Cupcake Jun 28, 2020
  19. S1575430891497
    Cupcake Oct 1, 2020
    S1575430891497 , Oct 1, 2020 :
    It was already enabled on my phone. Still I face same blank screen on Sony Bravia with my OnePlus 7t. But I can hear audio
  20. SRD.
    Lollipop Oct 2, 2020
