screen mirroring issue
  1. L1546497088771
    Donut Aug 11, 2020
    L1546497088771 , Aug 11, 2020 :
    I used to screen mirroring with my sony tv in my oneplus 6t mobile in cast screen option name of the TV will show up after few seconds it will automatically cancelled and it comes with a notification Registration failed in tv screen and in mobile name of the TV was disappear so I cant connect my tv with my mobile using screen mirroring please fix this bug or anyone who has a solution for this please share
    VanshiPruthi likes this.
  2. Caomhin
    Marshmallow Aug 11, 2020
    Caomhin , via OnePlus 6T , Aug 11, 2020 :
    Make sure that Enable Wireless display is enabled in the cast app, 3 dot menu.
    Also ensure both are connected to the same network.
    Also clear the Mobile Broadcasts App info Cache and App info Storage as well.
    You may need to reset the Cast option on the TV as well, you will have to check the TV manual on how to do this.
    drl431 likes this.
  3. drl431
    Nougat Aug 11, 2020
    drl431 , Aug 11, 2020 :
    I can cast to a similar Sony tv on a regular basis using an OP6 on 10.3.5 OOS (and previous versions). But you may have an issue with wifi. Try using an app like WiFi Analyzer to check wifi signal strength near the tv and also make certain there is not wifi interference from a neighbor using the same wifi channel.
    Caomhin likes this.
  4. #4
  5. Caomhin
    Marshmallow Aug 15, 2020
    Caomhin , via OnePlus 6T , Aug 15, 2020 :
    Others don't have an issue, as you have the same hardware its probably not a Bug.
    Sounds more like a TV issue, and that's a different manufacturer, so maybe the bug is in their software, OnePlus have no control over other manufacturers TVs.
    Check for a TV software update as well.
    Also Try the steps above to see if it can rectify your issue.
    drl431 likes this.
  6. Bhavyaaggarwal1989 , via OnePlus 8 Pro , Aug 15, 2020 :
    But the same tv is working fine with other phone and my old phone still. Only this new phone is not connecting so I think u r not pretty much helpful in this..
  7. Caomhin
    Still check for TV software update, if there is one available install it. Sometimes it can improve compatibility with various other devices.
    And this is being helpful, try it and see. Also try the steps mention in my other post further up, that might even fix the issue. But you won't know till you try all of what's been suggested.
    drl431 likes this.
  8. Bhavyaaggarwal1989 , via OnePlus 8 Pro , Aug 15, 2020 :
    Already tried everything..
  9. drl431
    Nougat Aug 15, 2020
    drl431 , Aug 15, 2020 :
    Did you turn on 2 way channel network acceleration? Try turning off that setting. Note that this setting would not apply here as you are posting in the wrong forum.
    Caomhin likes this.
  10. Caomhin
  11. Caomhin
