Screen not optimized or hardware problem? via OnePlus 8T
  1. r4wky
    Eclair Jul 30, 2021
    r4wky , via OnePlus 8T , Jul 30, 2021 :
    in some apps i don't get full screen properly, even on app drawer the scroll bar gets cut down when moved to the end, and in zoom app in full screen at the corner the text gets cut, is this the software issue or the h/w??? check this https://ibb.co/f22dqKZ
    Gor.V likes this.
  2. #2
  3. Gor.
    KitKat Jul 31, 2021
    Gor. , Jul 31, 2021 :
    Hey there.
    Firstly, that does happen with some apps and it's normal and based on the image you shared it looks normal to me too. If you feel it's beyond normal then it could probably be a case with your screen protector. Does your screen protector have thick black bezels/ border. That could be the culprit.
    Xcommunicad0 likes this.
  4. r4wky
    Eclair Jul 31, 2021
    Gor.V likes this.
  5. r4wky
    Eclair Jul 31, 2021
  6. #6
  7. Gor.
    KitKat Aug 10, 2021
    Gor. , Aug 10, 2021 :
    This also happens on my phone too. There's indeed a minor cut off with the scroll bar. However, that isn't anything to worry about. That's just how the phone display is designed and to be honest it barely cuts off the edge of the scroll bar.
  8. Gor.
    KitKat Aug 10, 2021
    Since you don't have a 3rd party screen protector on and based on the screenshot I see, this is, again, the default design of the phone. It's normal and nothing to worry about.
  9. r4wky
    Eclair Aug 16, 2021
    Gor.V likes this.
  10. Gor.
    KitKat Aug 24, 2021
