faizan.sg , via OnePlus 8T , Jan 24, 2021 : Post latest update on 8T I'm facing issue regarding screen usage and screen on time. The screen usage is not resetting after charging it 90%. I'm not able to get proper stats (SOT). The stats are refreshing only once in a week i.e on Sunday. Please help.
McJader , Jan 24, 2021 : It will only reset after a full charge If you want some changes, let OnePlus know here https://forums.oneplus.com/forums/community-feedback/
faizan.sg , via OnePlus 8T , Jan 24, 2021 : Thanks for your reply. But the before update the screen usage used to update on 90%. Now I need to fully charged my mobile to reset the stats.
Bharamdev , via OnePlus 8T , Jan 24, 2021 : This issue is happening with a lot of users. SOT used to reset when the charging percentage hit 90. Not anymore. It now resets on a Sunday, atleast that's what my battery stats are showing me.
psygarden , via OnePlus 8T Aquamarine Green , Jan 25, 2021 : Yes this is a known issue and will most probably be fixed with next update.
al_hasib.Fahim , via OnePlus 8T , Jan 26, 2021 : In my case, it resets if I charge the phone to 99% You can try it too. Charging your device to 99% will reset the battery stats.
R1611666197613 , via OnePlus Community App , Jan 26, 2021 : I think u should fully charge your battery.. Then try again
faizan.sg , via OnePlus 8T , Jan 26, 2021 : But this is not how Android is build. Every Android phone out there reset at 90%. This is bug and need to solve this asap.
al_hasib.Fahim , via OnePlus 8T , Jan 27, 2021 : Maybe it's a bug, maybe oneplus has introduced it as a 'feature' Even the nord has the same thing after oxygen os 11 open beta update
Emperor1993 , via OnePlus 8T Aquamarine Green , Feb 8, 2021 : Do not be conscious on your SOT. Just use, charge repeat and live a peaceful life.
TibiTibi , via OnePlus 8T , Feb 8, 2021 : Feature request? Maybe it could be reseted on demand, manually or customized treshold? This way we could fulfill most of the scenarios.
