Screen popping out of the body of ONE PLUS 3T .
  1. G_Prince_Pavan_S.Shetty_
    Cupcake May 23, 2018
    AnantOP3 likes this.
  2. AnantOP3
    Eclair Jun 4, 2018
    AnantOP3 , Jun 4, 2018 :
    Happened with my OP3 too.. Sent it to Delhi Exclusive Centre and they say that it is because the phone has been physically damaged which eventually caused the problem.. But there has been no such incident ever.. I always you back cover and tampered glass.. They say that the display will be changed and they'll charge around 7500 whereas the display is working perfectly fine..
  3. elanglois
    Lollipop Jun 4, 2018
    elanglois , Jun 4, 2018 :
    Remove SIM tray
    Remove two screws from bottom of device
    Gently snap it back together - Do not press on screen
    replace screws
    insert Sim tray
  4. G_Prince_Pavan_S.Shetty_
    Cupcake Jun 4, 2018
  5. AnantOP3
    Eclair Jun 4, 2018
    But the glue/tape has already come out.. I think it requires to be sticked back.. Display is working fine.. But what if the battery swell? How to ascertain that?
  6. AnantOP3
    Eclair Jun 4, 2018
    Was the screen coming out too?
  7. Ak@oneplus
    Gingerbread Jun 4, 2018
    Ak@oneplus , Jun 4, 2018 :
    Is that problem solved with battery replacement ??
  8. #8
  9. G_Prince_Pavan_S.Shetty_ , via OnePlus 7 , Mar 2, 2020 :
    The battery was popped out so yaah the problem got solved but later I had to use phone glue to stick the display so that it doesn't pops back
  10. B1512917123270
    Cupcake Mar 30, 2020
  11. pablofg1978
    Nougat Head Moderator Mar 30, 2020
    pablofg1978 , Mar 30, 2020 :
    Contact support or visit a service center asap, your battery may be degraded and it's pushing the screen
    Https://oneplus.com/support
  12. B1512917123270
