OxygenOS Screen recorder from 2018!? How is it possible!?
  1. E1541957484659
    Cupcake Sep 10, 2019
    E1541957484659 , Sep 10, 2019 :
    Hi!
    Since I updated the phone with the latest update (with the screen recorder) it has been some issues.
    First it used almost 1Gb of data, without me even using it once, not even started the recorder itself.
    Thought this was suspicious so I did a factory reset trough the menus in the phone, a "clean" factory reset with wiping the files and everything.
    Now when I look at it again is shows crazy date and I can't inactivate it, because it's greyed out.
    Why is it like this? And what's with the 1Gb of data usage that I have not used myself? And why does it say that the app is from early 2018?
  2. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Sep 10, 2019
    KeepTransisting , Sep 10, 2019 :
    Screen Recorder shares its data usage with Android OS, since it's a system app. So it's more than likely not using any data
    Kytharsis and Starcommander like this.
  3. E1541957484659
    I have that print screen of the huge data usage on a computer that I can't reach at the moment. I will upload it as soon as I can. Very strange.
