Screen Recorder Internal Audio Problem via OnePlus 6T
  1. Tanishq1plus
    Cupcake Oct 13, 2019
    Tanishq1plus , via OnePlus 6T , Oct 13, 2019 :
    Today suddenly , my One Plus 6t's screen recorder stopped recording the internal audio of my phone . I also checked the settings and everything was fine . My audio source was alo on "internal audio" . I was screen recording my game which I usually used to record.
    (Screenshot of Sreeen Recorder Settings)
    I want this to be fixed as soon as possible.
    J1579862034164 likes this.
  2. Seloo
    Cupcake Nov 16, 2019
  3. J1579862034164
    Cupcake Mar 18, 2020
  4. Caomhin
    Marshmallow Mar 18, 2020
    Caomhin , via OnePlus 6T , Mar 18, 2020 :
    Backup any recordings you have. Try clear your Screen Recorder app info Cache and Storage
  5. J1579862034164
  6. Caomhin
    Backup your phone data, then do a full factory reset. Either that or contact OnePlus support directly for more information on your issue.
    Scroll down the page for contact details.
  7. X1570696190151
    Cupcake Jul 30, 2020
    X1570696190151 , Jul 30, 2020 :
    Is your audio problem resolved?
  8. Y1597613793925
    Cupcake Aug 16, 2020
    Y1597613793925 , Aug 16, 2020 :
    I've cleared cache, didn't work with that but I disconnected my Bluetooth headphones and I think it works now, just started the game and it's recording again haven't recorded the whole gameplay walkthrough I was trying to record though! If problem reoccurs I'll update my answer. For now
    1. Clear cache of screen recorder
    2. If you are using Bluetooth headphones or just any headphones try disconnecting them and try recording again. Hopefully this will work.
  9. kranthi.r543
    Cupcake Oct 20, 2020
  10. Caomhin
    Marshmallow Oct 21, 2020
