Display Screen Reloading/Resizing issue with Android 11
  1. KalDog
    Cupcake Apr 8, 2021
    KalDog , Apr 8, 2021 :
    I haven't been having any issues since upgrading to Android 11 - even with doing a fresh clean install - except one annoying issue that prevents a lot of apps from working. Video of it happening here. With certain apps(and a LOT of them, too), the system will resize the screen if I don't do anything on the page for 4 or 5 seconds. Another fresh clean install didn't help either. I changed the display settings to disable the automatic resolution switch, and it happens when I don't have QHD enabled either, nor do I have any of the screen calibrations set. I've also tried setting it to 60hz mode, and a combination of all of the above settings to no avail. I've tried practically all available display settings here. Sometimes, when I lock the screen, it will resize the entire lock screen page and stay that way. It cuts off some numbers on the lock screen and I have to reboot my entire phone to actually use it again. This issue prevents me from using a lot of apps, as when it resizes it will basically kick me out of the app entirely and I have to enter login details again(for my banking and work app). Is there any fix for this, and is it a known bug? Like I said, I've done a couple of clean installs, including one from the recovery mode and another one from a local install using the updater(both clean installations). This is very annoying and I'm about to go back to android 10 if this issue persists!
    EDIT: Here it is freaking out on this thread like 3 times in 7 seconds.
    Pankaj_Rai likes this.
  2. Artemus.
    Community Hero 2020 Apr 10, 2021
    Best Answer
    Artemus. , Apr 10, 2021 :
    The only thing to do is roll back. That specific model doesn't play well with A11 as of right now.
  3. Artemus.
    Community Hero 2020 Apr 9, 2021
    Artemus. , Apr 9, 2021 :
    GM1915 (converted T-Mo)?
  4. KalDog
    Cupcake Apr 10, 2021
    KalDog , Apr 10, 2021 :
    Yep, known issue I assume? Any fixes or should I rollback?
  5. KalDog
    Very weird. Thanks for the information, for some reason I couldn't find anything about it but I didn't remember the gm1915 was a different model entirely. Appreciate it
    Artemus. likes this.
  6. Pankaj_Rai
    Gingerbread Apr 11, 2021
  7. Artemus.
    Community Hero 2020 Apr 11, 2021
  8. AliRao6
    Cupcake Apr 16, 2021
    AliRao6 , Apr 16, 2021 :
    I am facing the same issue but i can see that no one has a solution to this problem.. why oneplus is not rolling a stable update to its customers..
    muthazagan likes this.
  9. #9
  10. Artemus.
    Community Hero 2020 Apr 16, 2021
    Artemus. , Apr 16, 2021 :
    That's because there isn't a solution. It's the phone not cooperating.
    AliRao6 likes this.
  11. ZILLA07
    Cupcake May 2, 2021 at 11:06 AM
    steven889 likes this.
  12. steven889
    Cupcake May 5, 2021 at 8:29 PM
    steven889 , May 5, 2021 at 8:29 PM :
    Thank you very much, with this I solved it for the moment. to wait for a new update to fix this problem
