Screen stuck on boot Logo after applying update OPO Sultan Custom ROM
  1. aakash2101
    Cupcake Mar 14, 2016
    aakash2101 , Mar 14, 2016 :
    Hello,
    I have rooted my OPO. I have been using Sultan ROM. There was an update which I applied and after that the Startup screen came and then flashing of screen has started.
    It has stucked on the boot logo. I also tried applying restart billion times and tried to go into recovery mode, but still don't able to start my phone.
    Please Help me ASAP!!!
    I badly need it.
  2. rphlfjrd
    Lollipop Mar 14, 2016
    rphlfjrd , Mar 14, 2016 :
    Redownload the rom and reflash. Mount your phone via twrp to transfer files.
  3. AntMunny
    KitKat Mar 14, 2016
  4. se7enlyn
    Ice Cream Sandwich Mar 14, 2016
    se7enlyn , Mar 14, 2016 :
    list down the steps you took to flash the rom, and the version of your twrp and gapps.
  5. aakash2101
    Actually I don't remember the version of twrp and gapps but the rom is Sultan Backon CM 13 with 6.x.x. ... since i have done this first time I am an amateur in this.
    The steps are:
    downloaded the update.
    Then when click on the option update, the robooting process started.
    From then, the screen hasn't started the screen is just flashing on and off.
    This is the link of the update I just applied for your information..
    http://forum.xda-developers.com/one...m-kernel-unofficial-cyanogenmod-13-0-t3242700
  6. aakash2101
  7. aakash2101
    This is the link of the video of my phone's screen
  8. rphlfjrd
  9. aakash2101
    This is the video of my phone's screen
  10. rphlfjrd
    Hmmm. Can you access fastboot?
  11. se7enlyn
    don't update from the update option. download the full rom and do a clean flash.
  12. aakash2101
    Actually I researched alot and I found that probably its the problem of infinite boot looping...please help me out
  13. se7enlyn
  14. aakash2101
    How to do a clean flash bcoz its not going in recovery mode....
  15. se7enlyn
    long press power button until it switches off
    then once its off press volume down+ power button
    in recovery wipe everything except internal storage+otg
    look for the older rom in the phone, not the new update
    flash the older rom
    flash gapps
    wipe dalvik+cache
    reboot
  16. Sven j.
    Froyo Mar 14, 2016
    Sven j. , Mar 14, 2016 :
    If recovery mode is gone it looks like you soft bricked it so press the power button for about 40 seconds until the phone vibrates then press power button and Volumen up. When it boot s into fastboot mode download an older twrp Version Not 3.x.x.x-x which are very buggy and download ADB and SDK files and install it then run the command :fastboot flash recovery./xxxxxxxxxxxxxxxxx wherever you installed it on the pc. Then press power button until it vibrates and then press Volumen down and power button.
    You will bot into recovery now just copy the full Rom from the PC and flash it CLEAN that means also with system wipe, and you are good to go
  17. aakash2101
    Hey Thank you so much...i got all the problems solved...without losing any data...i m really thankful to u....
  18. anshukg
    Cupcake May 15, 2016
    anshukg , May 15, 2016 :
    if you are using TWRP do not select "ROOT" option, when it says your device doesn't seem to be rooted
    blueq likes this.
  19. Yaznas
    Gingerbread May 15, 2016
    Yaznas , May 15, 2016 :
    Download the Full ROM zip and gapps pico then put it in your internal storage and boot into TWRP by pressing n holding volume down n power button and in TWRP, install the downloaded zip n gapps
  20. blueq
    Honeycomb May 21, 2016
    blueq , May 21, 2016 :
    @anshukg
    Thank you for this suggestion:
    "if you are using TWRP do not select "ROOT" option, when it says your device doesn't seem to be rooted"
    it fixed my problem of boot-loop.
