Screen won't lock one plus 6 help!
  1. smoky1818
    Donut Jul 24, 2021
    smoky1818 , Jul 24, 2021 :
    Hi
    I recently went to store and changed my battery to new one and after turning on my phone I turned it on and it won't screen lock the phone when I press the pwr button and stays on for like 20m
  2. Tobikage
    Nougat Jul 24, 2021
    Best Answer
    Tobikage , Jul 24, 2021 :
    What store ?
    Did you consider going back and have them fix what was not broken ? o_O
    Did they mess up the connection somehow ?
    Install this and check if your power button is working.
    https://www.apkmirror.com/apk/oneplus-ltd/oneplus-diagnostic/
  3. smoky1818
    Donut Jul 24, 2021
    I don't think they messed up the pwr button since I was able to turn on the phone using charger cables connected and press pwr button to turn it on
  4. Tobikage
    Nougat Jul 24, 2021
    The diagnostic app will tell you if the button is working fine so confirm that first.
    Factory reset just in case and see if that helps.
    Caomhin, smoky1818 and drl431 like this.
  5. smoky1818
    Donut Jul 24, 2021
    I'm trying to download the app but when I goto the page it said it should auto download and it doesn't and there is a manual download and I press it and it won't download
  6. Tobikage
    Nougat Jul 24, 2021
    Caomhin and smoky1818 like this.
  7. smoky1818
    Donut Jul 24, 2021
  8. Tobikage
    Nougat Jul 24, 2021
    What browser are you using ?
    Or are you using the community app ?
  9. smoky1818
    Donut Jul 24, 2021
  10. smoky1818
    Donut Jul 24, 2021
  11. Tobikage
    Nougat Jul 24, 2021
    Because you copied just the incomplete text and not the actual URL link.
    The app is junk.
    Open Chrome and log in to the forum site.
    https://forums.oneplus.com/
    or just search apkmirror for oneplus diagnostic app on Chrome
  12. smoky1818
    Donut Jul 24, 2021
    I did finally download after logging in downloading to laptop and transfer to my phone and I used file manager to open and install the package app and I can't find it
  13. Tobikage
    Nougat Jul 24, 2021
    Reboot your phone and check again.
  14. smoky1818
    Donut Jul 24, 2021
    I can't reboot the phone because like u said pwr button is not working and ur rite I think they didn't connect the pwr connection properly
  15. Tobikage
    Nougat Jul 24, 2021
    You should still check with the diagnostic app just in case.
    Force stop the launcher app , let the app restart and check again if the Diagnostic app shows up.
    If it was working before you replaced the battery and stopped working after the battery replacement , that would be the logical conclusion.
  16. smoky1818
    Donut Jul 24, 2021
  17. Tobikage
    Nougat Jul 24, 2021
    Settings > Apps > Find the Launcher app in the list > Force Stop
    Hit the home button. That will restart the launcher app and refresh your app drawer / list.
  18. smoky1818
    Donut Jul 24, 2021
    Diagnostic app didn't show up
    I guess I'll just wait till battery runs out and when it shuts down try it out
  19. Tobikage
    Nougat Jul 24, 2021
    How exactly are you going to turn on your phone again if the power button is not working ? o_O
  20. smoky1818
    Donut Jul 24, 2021
    I plug in my phone and I was able to turn on.
    And after 10-15m screen goes black I have to plug in again and it opens
