2
Screenshot Issue....
  1. pratyush08
    Cupcake Sep 27, 2015
    pratyush08 , Sep 27, 2015 :
    Issue While taking screenshot....
    " Couldn't capture screenshot due to limited storage space , or it isn't allowed by the app or your organisation " Please help if anyone know resolution to this issue....
    Ceasedd and MKB4HD like this.
  2. RedNile
    Gingerbread Sep 27, 2015
    RedNile , Sep 27, 2015 :
    Download ES File explorer => show hidden folders => delete ".pictures" after taking a backup of the pictures inside it=> reboot => enjoy taking screenshots ;)
    Had this problem too on my phone (and it was really anoying :()
    robdam1001, sunilbagalur and Ceasedd like this.
  3. irasahai
    Cupcake Oct 16, 2015
    irasahai , Oct 16, 2015 :
    Had the same issue .. tried ur solution . it worked . YAY !!
  4. rishabhshah99
    rishabhshah99 , Oct 16, 2015 :
    Does the is any another trick to capture screenshot??
  5. rishabhshah99
  6. saqlainsyed007
    Cupcake Oct 31, 2015
    saqlainsyed007 , Oct 31, 2015 :
    Hey guys,
    You gotta follow these steps to get your screenshots up and running.
    1. Open file manager
    2. Look for PICTURES folder.
    3. Rename it to PICTURES2 or something
    That’s It…. Screenshots up and running….
    Now Why is that ? That's because the folder PICTURES is actually supposed to be Pictures. When you try to capture a screenshot, the screenshot app looks for a folder called Pictures but since it doesn’t exist, it tries to create it. But File Manager doesn’t differentiate between Pictures and PICTURES. Hence the error. When you do the rename and capture a screenshot you can actually see a folder called Pictures created. Now you can move the data from PICTURES2 to Pictures(Only the important one and without deleting any existing content in Pictures). It is safe to delete the PICTURES2 folder after this.
    (This Solution is tried by me on One Plus 2 and it worked).
  7. robdam1001
    Gingerbread Oct 31, 2015
  8. TwanLOL
    Gingerbread Nov 1, 2015
