SD 888 has issue of storage data copy and data access
  1. G_Atm_Sriram_oirp
    Eclair Jun 23, 2021
    G_Atm_Sriram_oirp , Jun 23, 2021 :
    Hello
    This is sriram from India
    Any experts of users of oneplus 9 can do let me know if you face the same issue ,
    I have recently purchased oneplus 9 , in Andriod Data Floder we cannot acces directly due to andriod 11 restrictions but we can install CX file explore or Zachiver etc,
    Perviously I used Oneplus 9R which is good SD 870 I can access data floder to rename and copy paste all example PUBG (Battleground Mobile India)
    but in Oneplus 9 ones I downloaded all the required I cannot see the data inside the floder only showing as 6 files inside the files when I open its showing only one showdow tracker extra issue is in Oneplus 9 or SD888 because my freind has MI 11X pro he has also same issue
    I cannot undersand how to acces tryied to all the way please let me know if any soloution
    T1612773059879 likes this.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 23, 2021
  3. G_Atm_Sriram_oirp
    Eclair Jun 23, 2021
    I have been using andriod 11 since last year , I know andriod 11 has this issue somehow all phones worked with Cx file but this one oneplus 9 is showing the same issue
  4. Caomhin
    Caomhin , via OnePlus 9 Pro , Jun 23, 2021 :
    Like I mentioned it can work with CX File Explorer and then may not. There are other file managers it works with too. But these are also hit and miss.
    It really is down to the implementation of the Scoped storage and how Google have dealt with that.
    Check the link below on how others have dealt with this. Some of the updates Google implement in their background updates may introduce further security updates and restrict the access further as time goes on.
    https://www.google.com/search?q=data folder in android 11&oq=data folder &ie=UTF-8
    Aaron2017 likes this.
  5. P1624109361389
    Gingerbread Jun 23, 2021
    P1624109361389 , Jun 23, 2021 :
    Hi.
    You can Use ES File Explorer.
    Also.in BGMI there is change in data folders due to security and privacy.
    It is not as same as GLOBAL VERSION.
    the_o2 and G_Atm_Sriram_oirp like this.
  6. sumitMZ007
    Jelly Bean Jun 23, 2021
    G_Atm_Sriram_oirp likes this.
  7. Slashbeetle.Labs
    Froyo Jun 23, 2021
  8. Y1546745610166
    Cupcake Jun 23, 2021
  9. the_o2
    OnePlus 9 Series Expert Community Expert Jun 24, 2021
    the_o2 , Jun 24, 2021 :
    Hi, if you doing particularly for BGMI then better to download it from Play Store directly as the early access is available for all.
    And you have to copy the OBB in Android > OBB folder not in the Android > Data folder.
    Caomhin likes this.
  10. G_Atm_Sriram_oirp
    Eclair Jun 24, 2021
    G_Atm_Sriram_oirp , Jun 24, 2021 :
    Yes I have downloaded BGMI and obb , and obb all working good but , I could not be able to zip the downloaded data and share to my friends from data floder with any file explore inside com.pubg.imobile -files-u4egame-showdowntrackerextra is showing 0 kb any one who using oneplus 9 or 9 pro please check the data floder with any file explore let me know can you able to see all 5gb data inside the floder.
  11. the_o2
    That is not showing, that's why the config method to force enabling 90FPS is not possible including Asus ROG 5.
    Caomhin likes this.
  12. G_Atm_Sriram_oirp
    Eclair Jun 25, 2021
    G_Atm_Sriram_oirp , via OnePlus 9 , Jun 25, 2021 :
    I found a solution bro , the whole data need to copy from system which is taken straight 8 hours , yesterday at morning I have made copy from my PC to phone at 10 am it's completed at 4.10 pm ,
    Highlight thing is that after copy when I open BGMI it's says croupted , than I renamed it and opened BGMI it was created the floder com.pubg.imobile , inside this which floder created files which could not be deleted so need to rename mentioned 1 than copied the file floder from previous one to this floder it's was taken less time done
    Opened BGMI working fine , now I can able to force 90 fps working fine
    But very complecated
    special note the whole data I have taken from oppo find x2 to pen drive than copied to system than system to OnePlus 9
    the_o2 likes this.
  13. the_o2
    OnePlus 9 Series Expert Community Expert Jun 25, 2021
    the_o2 , Jun 25, 2021 :
    8 hrs, this is too much...
    So those files and folders are visible and have write permission in PC ( windows I guess)?
    That's great, enjoy 👍🏼👍🏼
    Caomhin likes this.
  14. G_Atm_Sriram_oirp
    Eclair Jun 25, 2021
    Yes without write any permission it's worked , because I have adopted to 90 fps without that I can't play good so I have found my own solution for it Yes 8 hrs is very to much but no other option one time process ,
    But try with pendrive I didn't try , pendrive is taking less time but process is to follow
    the_o2 likes this.
  15. T1612773059879
    Cupcake Jun 27, 2021
    T1612773059879 , via OnePlus 9 Pro , Jun 27, 2021 :
    Can u make a youtube video ?
  16. Princeshh1
    Gingerbread Jun 27, 2021
    Princeshh1 , Jun 27, 2021 :
    Nice solution
  17. G_Atm_Sriram_oirp
    Eclair Jun 27, 2021
  18. T1612773059879
    The shadow tracker dosent open with the SD 888 devices .
    That's y I was asking for the copying from the system and 8 hours things .
    I couldn't fully understand that 8 hr process
  19. G_Atm_Sriram_oirp
    Eclair Jun 27, 2021
    G_Atm_Sriram_oirp , via OnePlus 9 , Jun 27, 2021 :
    Let me try to explain I am not good in English so please don't mind
    First if any of your friend using BGMI copy the whole data into pendrive or install sharit unofficially make the data in zip get sharit to your mobile,
    If u take it from pen drive than just rename the old file which is already there in com.pubg.imobile files into just add 1 than paste the whole data only the file floder into the floder com.pubg.imobile , don't create new one or don't try to delete the old one because it's won't accept , just rename iti will share the SS, after copied u can play game and copy paste in files is possible.
  20. T1612773059879
    So what I understand is , that I have to copy the data of bgmi ...then keep it in a pen drive
    Then install the game and copy and replace the folder .....
    Then the shadow tracker will be unlocked and I can play 90fps ?
