Searching for Wifi takes too long via OnePlus 8T
  1. kissoff
    Cupcake Sep 16, 2021
    kissoff , via OnePlus 8T , Sep 16, 2021 :
    I am trying to connect to my home wifi and the search takes too long (30-60 seconds). Other Android phones do not have such an issue here. Also, I don't live in a city so there are no hundreds of networks around.
    Once search is finished and I can connect there is nothing amiss. Connection happens and it is retained.
  2. pkg3107
    Ice Cream Sandwich Sep 16, 2021
    Best Answer
    pkg3107 , Sep 16, 2021 :
    You can try resetting Bluetooth and Network Settings. This should solve your issue.
  3. kissoff
  4. Gor.
    Lollipop Sep 16, 2021
    Gor. , Sep 16, 2021 :
    Hey there.
    Kindly check out the suggestions in the following link and see if it helps.
    https://www.carlcare.com/global/tips-detail/what-to-do-when-phone-won't-connect-to-wifi
    rHITkM., Caomhin and kissoff like this.
  5. proharsh1
    Honeycomb Sep 16, 2021
    kissoff likes this.
  6. BetaBot
    Jelly Bean Sep 16, 2021
    rHITkM. and Caomhin like this.
  7. kissoff
    After a restart the networks appear faster. Perhaps it is the network and Bluetooth reset that did the trick but required the restart to take effect, or the restart was all that was needed. I will post back if the issue reappears soon.
    rHITkM. and Gor. like this.
