2
Secret code not working with Android Pie OP6
  1. E1538074536085
    Cupcake Jul 22, 2019
    E1538074536085 , Jul 22, 2019 :
    Facing the same problem. with stock app, working for imei but not other codes. tried restart and everything.
    did you get any solution?
  2. sagar.ydrs
    Cupcake Sep 1, 2019
    sagar.ydrs , Sep 1, 2019 :
    Same here with Op3t pie and it's irritating.. :(
    Did anybody find any workaround??
    Starcommander likes this.
  3. Starcommander
    Lollipop Sep 1, 2019
    Starcommander , Sep 1, 2019 :
    There is an application on playstore. I had installed it to open that settings. I don't remember the name though
  4. risky1301
    risky1301 , Sep 1, 2019 :
    I know on some devices it can take up to 20-30 seconds for it to appear. I used to do it on my Nexus 6 and it took a while for the menu to come up.
  5. risky1301
    Yup, just tried it and it took about 25 seconds for the menu to appear! Not sure why the delay but non the less it worked! Hope it helps!
  6. sagar.ydrs
    Cupcake Sep 2, 2019
  7. sagar.ydrs
    Cupcake Sep 2, 2019
    sagar.ydrs , Sep 2, 2019 :
    Yes, thank you very much for the info.. I read the same thing on Reddit as well, the app's called "hidden settings".. this works!! :)
  8. G_Antero_Kulju_szbk
    Donut Sep 3, 2019
    G_Antero_Kulju_szbk , Sep 3, 2019 :
    Tested it with stock phone app and it didn't work. Changed the default phone app from another phone app i use to the stock in settings, and now it works.
  9. dannubt
    Cupcake Sep 3, 2019
