Selectively choose when to connect to a Bluetooth receiver via OnePlus 8 Pro Onyx Black
  1. AndyRM
    Gingerbread Nov 14, 2020
    AndyRM , via OnePlus 8 Pro Onyx Black , Nov 14, 2020 :
    I have a Bluetooth receiver connected to an amp and speakers. This is good for some of the time but sometimes I don't want to use this and I don't see anyway to manually select. Is there a method I'm missing?
    I don't want to switch off the BT receiver at others may want to use it and it's not easy to reach. I don't want to turn Bluetooth off all together on phone because workking with other sources.
  2. AndyRM
    Just to expand slightly. Yes I know I can turn off device as a media device. This only solves problem in one usage occasion only. Yes it won't switch on automatically following the switching off. Problem is that once you have used that device to send music too it automatically resets to media device and input source. You therefore would have to cancel both these switches following using for stabbing music each time.
