Selfie Portrait does not launch
  1. Sudarsen Cupcake Jun 25, 2019
    Sudarsen, Jun 25, 2019 :
    After the recent update, Selfie Portrait does not launch and camera app gets stuck. have to force stop and launch it again
    any fix for this?..
  2. Coolscorpio.karan Donut Jun 25, 2019
    Coolscorpio.karan, Jun 25, 2019 :
    Did you install the camera app via external APK? If so, you need to restore it back to original version and it will work.
    Kytharsis, Muhsin_Sultan and Phanitp like this.
  3. Sudarsen Cupcake Jun 26, 2019
    Sudarsen, Jun 26, 2019 :
    it's the phone's camera app.. no apk installation. how to restore the Camera app?.. i have disabled and enables it, still the same.
  4. drl431 KitKat Jun 26, 2019
    drl431, Jun 26, 2019 :
    Which version is your camera app?
  5. Sudarsen Cupcake Jun 27, 2019
  6. drl431 KitKat Jun 27, 2019
    drl431, Jun 27, 2019 :
    That is the camera app for an OP7 phone that you "side loaded" into an OP6/6t phone.
    Problems can occur when you manually install a system apk for a different phone.
    Disable the camera, tap 3 dots, then remove updates.
  7. Sudarsen Cupcake Jun 27, 2019
    Sudarsen, Jun 27, 2019 :
    no sideloading done.. all apps installed from Play store.
    only a phone update occurred this month with 2019.5 security patches and a few other bug fixes.
    anyways I followed your steps to uninstall updates, now it's working.. why would a OP7 camera update install on OP6?..
  8. B_Wrath Marshmallow Jun 27, 2019
    B_Wrath, Jun 27, 2019 :
    You are telling that you didn't download any camera APK manually from any site?
    Kytharsis, ironass and drl431 like this.
  9. D1544437680334 Cupcake Jul 11, 2019
  10. Kytharsis Marshmallow Jul 11, 2019
    Kytharsis, Jul 11, 2019 :
    Camera version?
  11. D1544437680334 Cupcake Jul 11, 2019
  12. drl431 KitKat Jul 11, 2019
    drl431, Jul 11, 2019 :
    To be clear, that was not an official camera update, but rather a side loaded apk for an OP7.
    Kytharsis and ironass like this.
  13. rohith.srivastav Gingerbread Jul 12, 2019
    rohith.srivastav, Jul 12, 2019 :
    without installing how the camera version changed from 3.0.16 to 3.2.91? you have installed external apk. uninstall it. it will work fine
