Service drops after updating. via OnePlus 7T
  1. Marco Giesing
    Cupcake Oct 16, 2021
    Marco Giesing , via OnePlus 7T , Oct 16, 2021 :
    After recently updating to OOS 11.0.3.1.HD65BA I have encountered random service drops several times per hour. My service will just go to no service for anywhere between 10 seconds to 1 minute or so.
    I did not change any settings, especially not regarding the simcard/network operations or anything.
    Also cleaned the simcard slot with compressed air but that did not do the trick. Obviously also made sure the simcard itself was clean.
    Tested the simcard on a different device aswell for about 3 hours. On that device the simcard worked correctly and I did not experience any service drops.
    While typing this thread the service already dropped once, again. Hope anyone got a fix!
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 16, 2021
  3. Marco Giesing
    Cupcake Oct 17, 2021
    Marco Giesing , via OnePlus 7T , Oct 17, 2021 :
    Thank you for the suggestion! Done it and will see if this fixes it. Never knew this was an option so fingers crossed.
    J4t1np4r3kh and Dresa91 like this.
  4. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 17, 2021
    Dresa91 , Oct 17, 2021 :
    Okay 👍🏼
    Finger crossed 🤞🏼
    Caomhin and Marco Giesing like this.
  5. Marco Giesing
  6. Dresa91
    Hm,… you can give a factory reset a try
    Caomhin likes this.
  7. J4t1np4r3kh
    OnePlus Accessory Tester Oct 17, 2021
    J4t1np4r3kh , Oct 17, 2021 :
    When the issue arises, have you tried just switching airplane mode on/off
    Marco Giesing likes this.
  8. Marco Giesing
    Cupcake Oct 18, 2021
    Marco Giesing , via OnePlus 7T , Oct 18, 2021 :
    Yes I have. Just tried it again now. It did work this time but I have had times where that also did not work. It is a bit 50/50 from what I have noticed. Thanks for the suggestion though 😃
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 18, 2021
    Dresa91 , Oct 18, 2021 :
    So give a factored reset a try to rule out a software issue
  10. dicovk
    Froyo Oct 28, 2021
    dicovk , Oct 28, 2021 :
    Having the same issue's after the update.
    wonder if topic starter issues were fixed after a factory reset.
  11. AndroidManiac
    Ice Cream Sandwich Nov 3, 2021
    AndroidManiac , Nov 3, 2021 :
    Any resolution for anyone yet???
    I updated to OOS 11.0.3.1 and no problems.
    Updated to OOS 11.0.4.1 and now i have the exact same symptoms it seems....... I'vd had this device (7T) since it was released and used every OOS update issued and never had this problem or any other problems along the way over the years (other than the L3 widevine)
  12. Marco Giesing
    Cupcake Nov 22, 2021
    Marco Giesing , via OnePlus 7T , Nov 22, 2021 :
    Hello! Since I wasn't able to do a factory reset back then I had to wait with it for a bit but after doing it today the issue was still there sadly. Any other idea's?
  13. Marco Giesing
    Hello, sadly the factory reset didn't fix the issue for me. Issue is still there
  14. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Nov 23, 2021
    Dresa91 , Nov 23, 2021 :
    You can submit a bug report or contact the support
  15. Marco Giesing
    Cupcake Nov 23, 2021
    Marco Giesing , via OnePlus 7T , Nov 23, 2021 :
    Okay so I found a weird "fix". Going into the network section and going from 2G/3G/4G (automatic) to 2G/3G (automatic) doesn't make my network drop anymore (so far for about this whole day).
    Was looking at the sim status this morning and it was pretty much constantly on HSPA+ but when it went to 4G it immediately dropped my network.
    That's why I changed to 2G/3G automatic instead of the normal one. Since then it hasn't dropped (for what I've seen or noticed).
    Hopefully some other people can try this to see if it does the same for them.
    Edit: Yes I do have a 4G bundle!
    Edit 2: This obviously isn't ideal but for the time being my network at least doesn't drop completely.
    Dresa91 likes this.
