Service/Engineering Mode
  1. SanjithaD
    Honeycomb Jul 26, 2014
    SanjithaD , Jul 26, 2014 :
    Hey does anyone know the code (i.e. The code you put in your dialer to get access to secret engineering stuff) that you need to unlock service/engineering mode on the Oneplus One? I want to check if all sensors and touch inputs are working optimally.
  2. cluster2a
    Gingerbread Jul 26, 2014
    cluster2a , Jul 26, 2014 :
    "About the Phone" --> klick 5 (?) times on "Build number"... do you mean this?
  3. Cuerex
    KitKat Jul 26, 2014
    SanjithaD likes this.
  4. SanjithaD
    so theres no way to do it without rooting atm?
  5. Cuerex
    KitKat Jul 27, 2014
    Cuerex , Jul 27, 2014 :
    to acces admin controls, you need admin privileges, as simple as that
    K1519548325326 and SanjithaD like this.
  6. SanjithaD
    Honeycomb Jul 27, 2014
  7. kkfong
    Cupcake Aug 7, 2014
  8. A N C
    Cupcake Aug 7, 2014
  9. kkfong
    Cupcake Aug 8, 2014
    kkfong , Aug 8, 2014 :
    Thanks for the secret code!
  10. gd6noob
    Froyo Sep 2, 2014
    gd6noob , Sep 2, 2014 :
    I have installed both but still can not access the Service Mode via *#0011#
  11. atomic_man
    Jelly Bean Jan 5, 2015
    atomic_man , Jan 5, 2015 :
    *#*#3646633#*#*
  12. ndipaolo5
    Honeycomb Apr 28, 2015
    ndipaolo5 , Apr 28, 2015 :
    I wish I could get this to work. I'm having primary microphone issues. I can do *#*#4636#*#* but *#*#3646633#*#* doesn't work... has anyone identified the correct code for the OPO?
  13. return.of.octobot
    Jelly Bean Apr 28, 2015
    return.of.octobot , Apr 28, 2015 :
    It is *#*#4636#*#*
    v.r.sankar likes this.
  14. ndipaolo5
    That gets you into the network-y type stuff. I'm looking for a ussd code that gets you into the settings for the other hardware, i.e. the microphones.
  15. wmm
    KitKat Apr 28, 2015
    wmm , Apr 28, 2015 :
    People using OxygenOS should be aware that, although this is the correct code, you can't enter it directly in the dialer: as soon as you enter *#*#, the dialing string disappears. You can do it, though, by entering 3646#*#*, moving the cursor back to the start of the dialing string, and then entering *#*#.
  16. SomeSayImHandSome
    Apr 28, 2015
    SomeSayImHandSome , Apr 28, 2015 :
    either flash color os. or install patch with recovery
  17. ThonyFD
    Cupcake Jul 21, 2015
    ThonyFD , Jul 21, 2015 :
    I have OxygenOS and I did this, but the dialing string still disappears, another idea?
  18. Vetali
    Gingerbread Jul 21, 2015
  19. Sushsich
    Honeycomb Jul 21, 2015
    Sushsich , Jul 21, 2015 :
    Why not try saving the string as contact n then try it by dialing the contact
  20. wmm
    KitKat Jul 21, 2015
    wmm , Jul 21, 2015 :
    I have no idea what is happening with your phone; I just did this again and it worked perfectly. The only thing I can suggest would be to type more of the string the first time around so that you have fewer characters to add at the beginning, e.g., type "#*#4636#*#*" and then move the cursor back to the beginning and add the "*". Again, that works for me; as soon as I've typed the "*" to the left of the "#", I get into the engineering screen.
    Aaron Alexander and pbergonzi like this.
