Set a specific and same ringtone for all my contacts
  1. roygordon
    Cupcake Apr 20, 2021
    roygordon , Apr 20, 2021 :
    I want to set a specific and same ringtone for all my contacts in my 7T.
    Can I do this, w/o going through them one at a time? I can't seem to find a way to do so. Thx.
  2. Yash Pratap Singh.
    KitKat Apr 20, 2021
    Yash Pratap Singh. , Apr 20, 2021 :
    By default, the same ringtone of the device is applied to all contacts. Go to settings - sound and vibration - ringtone and vibration. Then select your desired ringtone
  3. roygordon
    Thx.
    But let me be a little more specific. I want a different ringtone when I get a call from someone (or some scam) not in my contacts.
    The problem is the ringtone I select seems to apply to every call I receive, whether from my contacts or not.
  4. Yash Pratap Singh.
    KitKat Apr 20, 2021
    Yash Pratap Singh. , via OnePlus 7T , Apr 20, 2021 :
    Umm, you cannot do that brother 👀
    But what I suggest is that you install Truecaller and in the settings, allow Truecaller to mute the spam calls, so the spam calls will not ring or vibrate 😉
    J4t1np4r3kh likes this.
  5. roygordon
    Thanks for you response. I'll look at truecaller.
    Btw, other phones have allowed me to do this. Define a group and give that group its own ring tone. Contacts is predefined as a group that can be given its own ringtone. Oneplus should have this. I'm quite surprised it isn't there.
