Settings > System > Accesibility > Select to speak
  1. knudkp
    Cupcake Jun 24, 2021
    knudkp , Jun 24, 2021 :
    I updated my OP9 to Oxygen 11 2 7 7 LE25BA
    SUDDENLY AND OUTTA THE BLUE the "little man in the right lower corner" appears again.
    I tried to disabel him via
    By deafault is deactivated, but it the icon is back on my homescreen
    I DONT WANT IT THERE
    I WANT A SOLUTION FOR THIS - as I paid a great deal of money for this phone, and its not fair that I shall "reset my phone to dactory defaults" and use 5+ hours to reestablish all apps ... and settings every time this s**t happends.
    And yes ... I'm angry :)
  2. McJader
    Marshmallow Jun 24, 2021
    McJader , Jun 24, 2021 :
    This is a user forum, being "angry" or aggressive reduces chances of receiving help to a great degree.
    Have you checked if any other accessibility apps are active like Talkback or Switch Access?
    Sheppards, Caomhin, B_Wrath and 2 others like this.
  3. P1624109361389
    Gingerbread Jun 24, 2021
  4. camohan
    Moderator Moderator Jun 24, 2021
    camohan , Jun 24, 2021 :
    Hi there, please do not be angry.
    Have you tried toggling off the accessibility menu?
    Go to settings, systems, accessibility, accessibility menu and toggle it off.
    I hope this helps.
    Caomhin, Aaron2017 and McJader like this.
  5. knudkp
    Ofcourse :) It's just because ... everytime I contact OnePlus great customerservice, they suggest me to reset my phone to solve issues. I done that twice this week, and use 5 hours to setup around 179 apps everytime ....
    Via accessibility menu it IS turned offf ... but the icon still remains on the screen. I can even press it, but with no action oufcourse.
  6. McJader
    OnePlus Support doesn't know what they're doing half of the time.
    Could you share a screenshot of Accessibility menu as another user suggested?
    Caomhin, pkg3107 and Aaron2017 like this.
  7. knudkp
  8. knudkp
    I tried with screenshot
  9. McJader
    What about Talkback and Switch Acces?
    the_o2, Caomhin and Aaron2017 like this.
  10. knudkp
    I have tried a lot of things:
    - resetting my phone
    - updating the lates Oxygen
    - Wiping Cach during boot
    - Deactivating the system app that runs rtext to speak - evenm removing it
    nothing helps
    and today ... it suddenly appeared outta the blue .... again. This morning is wasn't there ... now it is - and me can't remove it ... but now I'm glad :) you guys are replying to my posts :)
  11. knudkp
  12. knudkp
    yeah ... thats a pretty wiered one ... I never had these issues with my OP6 phone .... but my OP9 has had many wiered issues since I got it in April
  13. McJader
    And Accessibility menu?
    Caomhin likes this.
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jun 24, 2021
    Swejuggalo , Jun 24, 2021 :
    You can take screenshots via the phone. Volyme down + power button and press the extended screenshot button. That way you can show the whole accessibility menu and bigger areas if necessary.
    Caomhin and McJader like this.
  15. knudkp
    McJader likes this.
  16. knudkp
    all disabeld
  17. camohan
    Hi there, I think I finally found out the solution.
  18. camohan
    @knudkp, go to settings, systems, accessibility, Niagara launcher, Niagara launcher short cut, toggle it off.
    If you want to keep the short cut, go inside and uncheck the boxes, see the screenshot below
    I'm sure once you toggle it off, the little man will never come again in your life.
    Cheers.
    Caomhin likes this.
  19. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Jun 24, 2021 :
    Not so sure he is the one using Niagara though
    McJader likes this.
  20. camohan
    Oh Lololo what an idiot I'm. That screen recording was yours, I thought it is the users.
    Infinite facepalm!
